Old 8/17/08, 11:26 PM
Richard W. Washington's Avatar
Richard W. Washington Richard W. Washington is offline
Default water heater rust
What would happen if rust built up enough to penetrate through the walls of the w.heater? Explosion?
This one was from a roof leak that took a while to get repaired?
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Based in Katy, serving Houston and all surrounding communities
Old 8/17/08, 11:33 PM
Jeffrey R. Pope's Avatar
Default Re: water heater rust
Usually just turns into a leak.
The only time there is a risk of explosion, is when/if there is no way for the pressure to be released. It happens in an instant when the water reaches temperatures that create steam.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/17/08, 11:41 PM
whandley's Avatar
whandley whandley is offline
Please Note: whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Is that a gate valve in the supply line directly above the right side stains and corrosion? I don't normally associate that type of corrosion issue with an intermittent roof leak. Is it possible its from supply plumbing and or prior worn valve? Not that it matters of course.
I'm in agreement with Jeff. I've seen many casings over the years with penetrations from rust large enough to put your hand through, but no leaks. Tank is totally separate from the exterior housing and or casing.
Old 8/18/08, 8:09 PM
I believe it was a gate valve. Yes, I'm in agreement with Jeff too. I told the young couple to go ahead and replace the unit.
Old 8/19/08, 2:53 AM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Most WHs are glass lined, and in truth I have seen them rust through to the lining.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 9:36 AM
TPR & Combusiton Air thejnicki Plumbing Inspections 16 9/18/06 8:55 PM
