Old 7/18/07, 8:28 AM
Scott Byrnes's Avatar
Scott Byrnes Scott Byrnes is offline
Default Water heater safety tank
What is the purpose of the water heater safety tank on top of a water heater?
Old 7/18/07, 8:56 AM
phinsperger's Avatar
Default Re: Water heater safety tank
"Safety Tank"? It looks like a typical expansion tank. Used to allow a space for water to go when heated and expands.
Old 7/18/07, 9:04 AM
David P. Valley's Avatar
That is an expansion tank.
The main purpose of the expansion tank is to compenate for the expansion of water due to heating it against a closed valve, check valve, or backflow preventor upstream of the water heater.
This expansion tank will basically give expanding hot water a place to go so the increase in pressure brought about by heating the water will be controlled and not cause a failure in the plumbing system. There'a a bladder in this tank that expands as pressured hot water enters, then the water recycles itself back into the plumbing system as it cools down.
Old 7/18/07, 9:06 AM
I figured it was an expansion tank, but I also figured it never hurts to verify. Thanks guys! It's good to be NACHI
Old 4/1/11, 7:02 AM
Rod Peters Rod Peters is offline
Please Note: Rod Peters is a non-member guest and is in no way affiliated with InterNACHI or its members.
Expansion tank is needed in a "closed loop" hot water sytem. Hot water from the tank is contiuously pumped in loop that returns to the water heater,usually where the drain valve was.
Old 4/1/11, 11:28 AM
Charles Lambert Charles Lambert is online now
Rod,
Please see David's post above as to the reason expansion tanks are in place.
Just remember they have an air fill valve like a bike or car tire and usually need to be set at 40 psi
Old 4/1/11, 2:22 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Temperature Pressure Relief valve vent is wrong.
Hope you noted that in your report.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
www.inspectorpages.com/kwood www.homegauge.com/shgi/THERIGHTTRAKIAQ
Cell: 705-971-2096
Ph : 705-946-2676
Old 4/1/11, 5:25 PM
Jeffrey R. Pope's Avatar
Looks like CPVC to me, which is allowed. In any event, the post was from 4 years ago, so I think he would be off the hook by now
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/1/11, 5:52 PM
KEVIN WOOD's Avatar
Look closer Jeff.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 4/1/11, 6:50 PM
Is it disconnected? It's hard to tell on my tablet screen...
Jeff Pope
Santa Clarita CA
(661) 212-0738
Water Heater Dip Tube Failure jacaron Plumbing Inspections 2 2/25/07 12:28 AM
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 10:36 AM
TPR & Combusiton Air thejnicki Plumbing Inspections 16 9/18/06 9:55 PM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 6:58 PM
