Old 11/9/11, 8:35 PM
Amir Faghih Amir Faghih is offline
Default when water heater should have expansion tank
I need clarification as to when there must be expansion tank near water heater.
I understand, that if there is pressure regulator in front of main water meter, then there must be an expansion tank for water heater. BUT, new generation of pressure regulator eliminates the need for expansion tank. Is that correct?
Thanks for your help.
Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/9/11, 8:41 PM
Bob Elliott's Avatar
Default Re: when water heater should have expansion tank
Anytime there is a booster pump or check valve for instance unless you like the tpr valve tripping
Old 11/9/11, 10:25 PM
James E. Braun, CMI's Avatar
It is mainly a code requirement. Usually in my area you can install expansion tees instead of tanks.
Braun Inspection Consultants
Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Water heater expansion tank jfrederick Plumbing Inspections 3 11/17/08 3:35 PM
Water heater expansion tank jfrederick Plumbing Inspections 0 11/17/08 8:18 AM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 13 1/11/06 9:53 PM
