I thought I had seen a chart giving basic rules for correctly sizing a water heater in residential homes. You know 3 bedrooms 2 1/2 bath requires ???? minimum. Anyone know where this can be found.
Thanks |
http://www.lowes.com/lowes/lkn?actio.../WtrHtrBG.html
http://www.buygasappliances.com/Prod...erHeaters.aspx Bedrooms do not use hot water, people do. |
Brian,
Did you have a bad night or are you usually that sarcastic? There is a code that determines the minimum size of a water heater in a residential home depending on the number of baths and bedrooms. |
Jeff Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Charles,
Nothing to fret about. Brian has keen sense of humor and likes to share it with everyone here. Pay attention and you'll "get" him after a while. |
Not sure of the code you are referring to? |
Michael.
I'm not fretting. I take it all with a "grain of salt". After all I work with R/A's all day......that should count for something...... |
Just wanted to let you know that Brian is alright. |
Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
IRC P2801.1 Required. Each dwelling shall have an approved automatic water heater or other type domestic water-heating system sufficient to supply hot water to plumbing fixtures and appliances intended for bathing, washing or culinary purposes. Storage tanks shall be constructed of noncorrosive metal or be lined with noncorrosive material. In my area, there is a heavy Amish population, who don't all use water heaters. The code does allow for "other type domestic water-heating system...", which the inspectors permit to be a pot of water heated on a the stove and delivered via people power to the fixture that it's going to be used in. Last edited by Marc D. Shunk; 6/28/07 at 9:36 PM.. |
Family Size Tank Capacity (in gallons) ...Electric Gas Oil 1-4/ 50 ..30 ..30 6 /...65 ..40 ..30 8+/ .80 ..50 ..30 This is not a code, just a table that shows which type of heaters have the fastest recovery. It depends on many things. Do you wash clothes in cold water, run the dishwasher once a day or once a week. Cold showers, on and on. Last edited by ccurrins; 6/28/07 at 11:56 PM.. |
jschulte is a non-member guest and is in no way affiliated with InterNACHI or its members.
My bedroom uses water. But in order to be earth friendly we get all of the water from the holes in the roof.
Brent Potter is a non-member guest and is in no way affiliated with InterNACHI or its members.
the UPC sizes water heaters based on their first hour recovery rating.
here is the chart in PDF format. http://www.reliancewaterheaters.com/...foreYouBuy.pdf Keep in mind this is first hour rating, not tank volumn. a 50 gal tank could have a 54 gal FHR or an 80. |
| Client wants a new water heater | adirienzo | General Inspection Discussion | 47 | 7/14/10 3:03 PM |
| Water Heater Dip Tube Failure | jacaron | Plumbing Inspections | 2 | 2/25/07 12:28 AM |
| Venting an oil-fired water heater | mh718 | Inspecting HVAC Systems | 3 | 11/16/06 10:36 AM |
| TPR & Combusiton Air | thejnicki | Plumbing Inspections | 16 | 9/18/06 9:55 PM |
