Old 2/7/13, 12:57 PM
Jeff L. Gollaher, CMI's Avatar
Jeff L. Gollaher, CMI Jeff L. Gollaher, CMI is offline
Default Water Heater TPR valve on the Hot water line
This was a first for me.
The water heater has the normal TPR installed on the side of the unit.
Then on the top of the unit there is a TPR valve installed on the hot water line to the home?
Is this a home owner install? seems like over kill to me.
Any thought on this
Serving the Greater Sacramento Area
Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/7/13, 1:10 PM
Bob Elliott's Avatar
Default Re: Water Heater TPR valve on the Hot water line
Hmmm need to think about that one.
Replacement (DIY) for a bladder(expansion) tank ?
Old 2/7/13, 5:56 PM
mtyson mtyson is offline
Bob,
You are all over it. As current codes require a device for controlling thermal expansion of the water supply and can not utilize the TPRV of the heater "Harry Homeowner" attempted to comply, but installed on the hot water out instead of the water supply side
Mark S. Tyson
M Tyson construction LLC
Tyson Home Inspections
Certified General Contractor #1516843
Florida Licensed Home Inspector #1824
Member N.A.C.H.I.
IAC2 certified
Member Florida Building Officials Association
http://www.TysonHomeInspections.com
Whats Wrong with this WH? jfunderburk Plumbing Inspections 37 4/4/12 8:50 AM
Shut off valves required? jcahill Plumbing Inspections 11 9/2/08 1:07 AM
small valve on cold water supply ahead of water heater? Walt Hoffman Plumbing Inspections 6 1/23/06 7:44 AM
