The water heater vent had 5 elbows. The furnace was 3 years old and a liner was installed. The flue for the furnace was properly installed.
I called out the water heater flue. Do you think the corrosion at the top of the tank is from improper drafting of the flue? Does any one have any references on water heater flues Thanks |
Since the rust is localized, it would lead me to believe that there is (or was) a leak above the unit. Most of the rust from backventing that I've seen has been more evenly distributed - but anything's possible.
Happy New Year!! "A man cannot be truly grateful and remain unhappy"
http://www.SmithHomeInspection.com SmithHomeInspection@yahoo.com NY State Lic. # 16000008304 631-434-5200 |
5 (FIVE) elbows ???? That's definitely too many elbows. I see an old mortared hole (in the chimney) right next to the water heater. They could have removed that mortar (seal) and used that side of the chimney. This installation will cause excessive condensation and rusting of the vent connectors. Fuel burning water heaters shall be vented to the building exterior. The vent must extend from the top of the water heater at least five feet in length above the highest vent collar (CPC 517.2). The vent shall terminate at least one foot above a roof that is flat to a roof sloped 6/12 (CPC 517.3). If there is a horizontal section, that horizontal section's length can only be 75% of the total height of the vent pipe (CPC 516.3) The horizontal section must have a continuous upwards slope of 1/4-inch/one foot (CPC 516.4). As to the rusting at the top of the WH...I'll bet if you place a flashlight on top of the rust spot (pointing straight up towards the ceiling), you'll locate the source of leaking (past or present). Last edited by dvalley; 1/4/07 at 12:05 PM.. |
| Water Heater Dip Tube Failure | jacaron | Plumbing Inspections | 2 | 2/25/07 12:28 AM |
| Venting an oil-fired water heater | mh718 | Inspecting HVAC Systems | 3 | 11/16/06 10:36 AM |
| TPR & Combusiton Air | thejnicki | Plumbing Inspections | 16 | 9/18/06 9:55 PM |
| Flue vent connection for water heater | hspinnler | Plumbing Inspections | 11 | 5/11/06 10:56 PM |
