This doesn't look right, is this some type of new installation? How would one write this up? Any input would be greatly appreciated.
![]() Thanks! |
That looks like dryer vent which is not approved
Thanks Wayne I was just making sure because there is a new flex vent material that is being used now that looks like a dryer vent right?
Yes there is but that isn't it , I truly believe that is dryer vent,
http://www.stovesonline.co.uk/flue/i...lue-liners.jpg
It looks more like this |
Yeah your right, Thanks I really appreciate it.
I didn't know since I haven't actually seen those new liners
Better to ask Steven , One thing for sure you get a answer here. Everyone has to ask something sometime or another. Another reason this is good spot for information
I know, you can never ask too many questions. We all continue to learn by doing so, especially on this message board.
And the water pipe looks combustible. It's in contact with the dryer vent, I mean water heater flue.
A liner is different than what is needed there. A liner is just that...a chimney liner.
Your picture looks like this: http://www.idealtruevalue.com/servlet/the-52299/Detail This type could be used with the correct clearances and needs the correct terminations: http://www.supplyht.com/SHT/2000/03/Files/Images/140813.jpg InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
i was using the liner to show the difference because i couldn't find the flex pipe. Didnt mean to side track you Steven but i know you got the idea
Also this looks like 4" flex connecting to a 3'' galvanized pipe with no clamp!! It looks like it could be leaking CO around that connection!!
You should also check the clearance requirements of heaters installed like this. The information is typically included on the data-sticker of the unit.
Most require a minimum of 12 inches clearance from the top off the unit to combustibles. Many Bradford Whites need up to 16 inches. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| Water Heater Powered Vent Material | jevans | Plumbing Inspections | 14 | 3/13/08 11:53 PM |
| Gas water heater vent pipe? | pcloninger | Plumbing Inspections | 5 | 2/1/08 7:17 PM |
| water heater recall | bwiley | Plumbing Inspections | 3 | 2/22/07 8:40 AM |
| Hot Water Heater | djohnson6 | Plumbing Inspections | 12 | 12/28/06 10:18 PM |
