Old 1/19/10, 8:00 PM
Sean Fogarty's Avatar
Default Water heater vent. Need Help
Is PVC acceptable on a power assisted water heater vent fan. I have seen braided metal, but not pvc. I would think not but want to know for sure.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Need a home inspection in Louisiana? Check out InterNACHI's listing of Louisiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/19/10, 8:03 PM
Default Re: Water heater vent. Need Help
Yes... Any water heater that has a PVC vent is typically very efficient taking most all the heat out of the exhaust gases.
Larry Kage, CMI
231 929 3525
Old 1/19/10, 8:12 PM
Larry, I don't understand your answer? How is the pvc making it more efficient? It is a older bradford white plain old gas water heater. I don't even understand why there is a need for a fan to begin with. Please explain further.
865-256-5397
Old 1/19/10, 8:27 PM
Sean, the PVC does not make it more efficient.
A high efficiency water heater takes so much heat out of the exhaust that it won't draft properly. It is too cool. It needs a fan to push it out the vent.
Because the exhaust is so cool, PVC can be used for venting without worry of melting or fire.
Larry Kage, CMI
231 929 3525
Old 1/19/10, 9:22 PM
James E. Braun, CMI's Avatar
Think of it as a high efficiency boiler/furnace.
Old 1/19/10, 9:34 PM
Marcel Gratton's Avatar
In my area, ABS is no longer acceptable and PVC is the norm.
The WH in pic is power vented which means that air is mixed to the exhaust gas to bring its temperature down so that plastic pipes could be used as flue.
Plastic flue pipes do not always means that the appliance is a high efficiency unit.
My thoughts,
On The Level Inspection
Gatineau, Québec
Old 1/19/10, 9:38 PM
Thank You Marcel!! I just found what you said somewhere else. It makes sense, and I did not think about the added air. All of the others I have looked at had corrugated metal instead.
865-256-5397
Old 1/20/10, 12:00 AM
Michael Larson's Avatar
They are not necessarily more efficient but the forced draft ensures that sufficient room air mixes with the hot flue gases to lower the temperature and make it safe to use PVC and side wall venting.
Michael Larson
Hudson, WI
Old 1/20/10, 12:31 AM
Mark E. Northrup's Avatar
Mark E. Northrup Mark E. Northrup is offline
It is just like a High eff. Furnace. they use pvc.
House 2 Home LLC
503-602-1420
HomePros@House2HomeLLC.ORG
Protecting Peace of Mind One House at a Time
IAC2 Certified
IR Certified
A favorite place on Google Maps
Old 1/20/10, 1:01 AM
Bob Elliott's Avatar
Schedule 40 is used.
Here is a link to install manuals.
The vent stuff is around page 15 on most.
http://www.hotwater.com/lit/im/r-gas.html
Water Heater Powered Vent Material jevans Plumbing Inspections 14 3/13/08 10:53 PM
Gas water heater vent pipe? pcloninger Plumbing Inspections 5 2/1/08 6:17 PM
water heater recall bwiley Plumbing Inspections 3 2/22/07 7:40 AM
Hot Water Heater djohnson6 Plumbing Inspections 12 12/28/06 9:18 PM
