Old 7/17/07, 7:08 PM
Deborah Siebern's Avatar
Deborah Siebern Deborah Siebern is offline
Talking Water Heater-What's wrong with this picture?
See anything unusual?
water-heater-whats-wrong-picture-water-heater.jpg   water-heater-whats-wrong-picture-water-heater-2.jpg   water-heater-whats-wrong-picture-water-heater-3.jpg   water-heater-whats-wrong-picture-water-heater-4.jpg
Old 7/17/07, 7:11 PM
tdietrich1's Avatar
Default Re: Water Heater-What's wrong with this picture?
Missing the two hose clamps and piece of garden hose?
tom
Old 7/17/07, 7:18 PM
Shouldn't there be a funnel in the lower section of the TPR drain???
Old 7/17/07, 7:25 PM
You guys are funny!
Old 7/17/07, 8:12 PM
Jeffrey R. Pope's Avatar
It looks like an attempt to fix a mistake.
The TPRV is required to be plumbed independent of other drains. The PRV was tied into it at one point (I am speculating) and it was cut away when the error was discovered.
Other than that, it looks like a pretty standard installation, although I have always questioned the true efficiency of having a timer installed.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 7/17/07, 8:26 PM
Michael R. Boyett's Avatar
If the TPRV ever discharges, the steam will blow straight up and not to the exterior and/or within 6" of the ground. The vertical piece from the TPRV should be capped or removed.
Old 7/17/07, 8:31 PM
Thanks Jeff. If I had a prize, you would have won it! I thought it looked a bit obscure. Thanks again for the constructive comments.
Old 7/17/07, 8:40 PM
You're right Michael. I think it needs a total make over, but since it is getting up there in age, I think they were just going to replace it to avoid any mishaps.
Old 7/17/07, 8:48 PM
Leonard E. Ungar's Avatar
Leonard E. Ungar Leonard E. Ungar is offline
Amazing / Simply Amazing
Old 7/17/07, 9:20 PM
The problem is, they replace the heater, not the discharge piping. As Mike said, at minimum, the vertical piece should be capped.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 7/18/07, 11:23 PM
thirst's Avatar
thirst thirst is offline
Hey at worse case they at least have the fire extiguisher right there handy in case of problems.
Travis Hirst
Hirst Home Inspection and Inventory Services, LLC
www.HirstHome.com
Travis@HirstHome.com
Hot Water Heater Question mpeterson Plumbing Inspections 8 3/31/07 2:59 PM
Hot water heater question mgeddie General Inspection Discussion 15 6/7/06 2:00 PM
Water heater strapping in manufactured homes ilpowell Plumbing Inspections 10 2/24/06 6:20 PM
HVAC / Water Heater Flue abishop Inspecting HVAC Systems 5 2/22/06 12:30 PM
Water Heater djames2 Plumbing Inspections 4 2/14/06 8:49 AM
