interesting article
mario Last edited by mkyriacou; 10/24/06 at 12:17 AM.. |
It was interesting, especially since the manufacturer's recommended setting is usually 120°F-125°F, and the article says that anything under 140°F will allow Legionnaire's Disease to incubate. Hmmmmmmmmmmm. Seems like the water heater manufacturers would have picked up on that.
lkrausz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Wont anything over 120 degrees burn small children on contact?
thus the requiremnet for the tempering valve
lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
The mixing valve will not allow water to exceed 120 degrees.
Many plumbers do not know if they take the handle off they can set the inside to raise the temp to 120 degrees. Roy Cooke Royshomeinspection.com . |
About Homes NACHI 2005 U.S. Member of the Year
Russel
Thanks For Info!! Resposible Parents Should All Know This Info. Mario 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
Here is the time to burn info for a child's skin.
Water Heater Safety.pdf He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
Or they were under the influence of Ms Margarita and Dr Cuervo.
most new water heaters come set all the way down so the installer is forced to adjust the temp. thus relieving the manufacturer of the responsability of scalding. The temps set in NH are 120 at showers and 130 at sinks. Our town requires the mixing valve mainly because a 40 gal water heater does not get the proper first hour gallon rating required by the plumbing code. By installing the mixing valve you can over fire the water heater to 160 and temper it down to 130 by adding cold resulting in more gal. per hour of hot water. This also a way to install a smaller water heater when you have a large whirlpool and not size the heater to match a fixture that gets used so little. A plumbing inspector showed me a quick way to test temps that is really amazingly accurate, on a sink, if you can hold your hand under the hot water for roughly 3 or 4 seconds befor it starts to burn that should be about 130. If you can't keep it for even a second, tooooo hot.
twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
Our local plumbing inspector would fail you if it were set over 120 degrees. It’s a catch 22 situation- Legionnaires disease or law suits for burns.
