Hi everyone,
Quick question for you? Do you call out the fact that a W/H is not up off the floor if the W/H is in a Closet in the Garage? It is getting combustion air from the attic or venting. I know Code(we are not code inspectors, I know) calls for it to be up off the floor in the garage, but the closet makes me question that. Especially the fact that it is getting air from a vent/attic. |
for electric hwh on floor is fine, i suggest pan and drain
for gas hwh must be off floor and protected by driveway block, and flow of air |
The reason it is required to be 18" above the floor is that gasoline fumes hover down near the floor.
Even if it gets its combustion air directly from somewhere else I believe it still needs to be up 18". |
If it is in the garage on the floor (electric) it must be guarded from a car hitting it.
Me thinks electric WH's should be elevated.
"IRC 2006 M1307.3 Elevation of ignition source. Appliances having an
ignition source shall be elevated such that the source of ignition is not less than 18 inches (457 mm) above the floor in garages. For the purpose of this section, rooms or spaces that are not part of the living space of a dwelling unit and that communicate with a private garage through openings shall be considered to be part of the garage." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
ekartal6 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Thanks Joe. Gas or electric it must be at least 18'' no exceptions.
I run into many inspectors that think electronic ignition is an exception. |
jhugenroth is a non-member guest and is in no way affiliated with InterNACHI or its members.
There's been lots of debate about electric water heaters needing elevation. The c*de references the "ignition source" and where is that with an electric water heater?
Per Florida Building Code
P2801.6 Water heaters installed in garages. Water heaters shall be installed in accordance with the manufacturer’s installation instructions which shall be available on the job site at the time of inspection |
read the code - element or burner.
""IRC 2006 M1307.3 Elevation of ignition source. Appliances having an ignition source shall be elevated such that the source of ignition is not less than 18 inches (457 mm) above the floor in garages. For the purpose of this section, rooms or spaces that are not part of the living space of a dwelling unit and that communicate with a private garage through openings shall be considered to be part of the garage." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 13 | 1/11/06 9:53 PM |
