This state water heater, natural gas, 1998, has a vent through the sill plate to what looked like a gas fireplace type termination. but it appears to me from the size that someone just brought the old gas chimney down to the water heater. It doesn't seem to have a power vent.
Anyone seen one like this? Should it have a standard open draft chimney fitting and go above the roof?2008 3 13 cobb and montfort 005.jpg |
I highly doubt that heater is intended for sidewall termination. The lack of a draft hood makes me question how well it drafts to the exterior. Consult the mfgs. documents or rep. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
But unless this unit is certified for sidewall venting and that is the approved vent system, all installed properly, some yahoo is putting a family in danger. |
A natural draft appliance WILL NOT vent properly without a draft hood. This installation is wrong, no matter how you look at it.
Brian. I wasn't very clear in my draft statement. My concern was indeed that ther would be draft problems resulting in flame lifiting from the burner. In short, it's a mess.
It has a Direct-vent design that draws combustion air from outside the home ensuring a sufficient air supply for proper heater operation. The "Coaxial” direct-vent system combines venting and air intake channels in a single pipe, requiring only one opening in the outside wall. |
In any case, the vent flue appears to be too big for that size water heater.
Ditto, no draft hood, side vent, etc. DIY special, always dangerous Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
A close-up pic of the outside vent cap would help. It could be drawing air thru the outer lining as proposed already. Page 3-5 of this manual shows a DIY installation.
http://www.gsw-wh.com/pdfs/products/...directvent.pdf Last edited by jkogel; 3/18/08 at 7:58 PM.. |
I don't know of any Direct-Vent Water Heaters that are not induced fan forced. They also have limitations on elbow design and length of total H/V run.
Your pic, and unit shown just can't be legal/safe. IMHO |
Ian Gills is a non-member guest and is in no way affiliated with InterNACHI or its members.
Bradford White do a direct vent water heater without a power vent. As proposed several times now, it could be drawing air through the outer lining of a dual-lined flue.
| New Washington Legislation Submitted | gdomagala | Legislation, Licensing & Legal Issues for Inspectors | 294 | 2/10/08 1:20 AM |
