Old 2/18/11, 10:57 PM
Jay Mathy Jay Mathy is offline
Default Water meter flow needle spinning back & forth
On my inspections I always look at the water meter to see if the flow needle is stopped when all the water is off in the home. Today I saw something new. The flow needle was turning slowly forward then backwards, stopping, then forward then backwards and stopping ... it just kept doing that. I looked at the meter next to it just for comparison it was stopped and steady.
Anybody know what this is an indication of ?
Need a home inspection in Kentucky? Check out InterNACHI's listing of Kentucky certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/19/11, 7:14 AM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is online now
Default Re: Water meter flow needle spinning back & forth
Sounds like a back flow issue.
Comprehensive Building Consultants
Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection.
Donate here:
or send checks to the
Fl Home and Insurance Inspector Chapter
1103 W Hibiscus Blvd Ste 311
Melbourne, Fl 32901
Old 2/19/11, 8:36 AM
mnahrgang's Avatar
Water heater kicking on and off? (heats the water up, it expands causing back flow, then goes forward as it cools?)
Mark Nahrgang
www.HeyMark.info
Old 2/19/11, 9:01 AM
Dale Duffy's Avatar
Either it needs one, or the existing repaired.
Old 2/19/11, 7:18 PM
That sounds feasible Mark but besides the fact that the water heater was turned off I think it was happening too fast to be that. The motion was moving like; Forward one thousand, two thousand, three thousand, four thousand - Backward one thousand, two thousand, three thousand, four thousand - Stop one thousand one, one thousand two, one thousand three, one thousand four, one thousand five - Forward one thousand, two thousand, three thousand, four thousand - Backward one thousand, two thousand, three thousand, four thousand - Stop one thousand one, one thousand two, one thousand three, one thousand four, one thousand five ...
Old 2/19/11, 7:53 PM
Robert Ernst Robert Ernst is online now
Recommend the water company come out and look at it. Also suggest a back flow prevention be repaired or installed. You could easily be causing a cross-link contamination to the neighbors. It could also be that there is someone taking water from a hydrant somewhere if they are tied to the municipal water.
Fighting Mold — The Homeowners' Guide from CMHC mkyriacou IAC2 Indoor Air Forum 1 9/17/09 2:32 PM
