Old 6/8/06, 3:21 PM
inspector@carolina.rr.com inspector@carolina.rr.com is offline
Please Note: inspector@carolina.rr.com is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Water Pipe Corrosion
I see this type of corrosion on water pipes a lot. I usually write it up as possible pinhole leak and investigate/repair as necessary by a plumber. I touched the area and felt no water. Should I just let this stuff go or write it up every time? Thanks.
Old 6/8/06, 8:03 PM
rlind rlind is offline
Default Re: Water Pipe Corrosion
I'd write it up every time myself......
Old 6/8/06, 8:22 PM
Dale Duffy's Avatar
From the picture it appears an amateur surely did the soldering. Excessive flux will cause discoloration as well as a leak.
Old 6/8/06, 8:36 PM
David P. Valley's Avatar
I concur with Dale.
Green build-up... The Plumber failed to wipe off the flux when soldering the pipes together.
If it were a pinhole leak, it'll be a white crusty salty substance built-up around the leak.
Old 6/8/06, 8:55 PM
twasion twasion is offline
Please Note: twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
This is just sloppy work. Sadly, I’ve seen this kind of work from seasoned professional also.
Old 6/9/06, 9:04 AM
Russel Ray's Avatar
I agree with David, who concurred with Dale, and I don't write it up.
Old 6/12/06, 6:37 PM
dgagne1 dgagne1 is offline
I would like to think that a guy trying to be a plumber would have left it like that and not a plumber.
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 36 10/27/10 11:21 AM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 9:16 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 7:39 PM
