Old 5/16/09, 5:39 PM
Default Water Pressure
Is there an accepted method to test for proper water pressure at the fixtures. What do others do?
Putting a guage on the hose bib will tell you what the pressure is in the main but it won't tell you if the curb valve is partially closed.
Find an InterNACHI certified Wisconsin Home Inspector (and anywhere else in North America)
Old 5/16/09, 7:31 PM
Jeffrey R. Pope's Avatar
Default Re: Water Pressure
A partially closed valve will not effect static pressure, it will only effect volume. I usually check pressure at the water heater (many will advise against that), because the pressure at the heater will be (should be) the same as the house-fixtures and appliances.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 5/16/09, 7:34 PM
Michael Larson's Avatar
Originally Posted by jpope View Post
A partially closed valve will not affect static pressure, it will only affect volume. I usually check pressure at the water heater (many will advise against that), because the pressure at the heater will be (should be) the same as the house-fixtures and appliances.
I would advice against but only because of the high probability it would leak afterward because of the high calcium content in our water(especially well water) the valve often gets sediment in it ans will not seal.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 5/16/09, 7:36 PM
I carry caps for that eventuality. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 5/16/09, 7:43 PM
But volume (ie flow) is what people care about. I agree that a pressure test at the hose bib or water heater only tells you the static pressure and will not indicate a partially closed curb valve.
Old 5/16/09, 8:03 PM
John,
Run the sink, run the tub and while they are flowing flush the toilet and observe any changes in flow rate.
It's called functional flow.
Report what you observe and move on.
Michael Larson
Hudson, WI
InspectraPro
and
Old 5/17/09, 6:27 AM
Brian E. Kelly's Avatar
Originally Posted by mlarson View Post
John,
Bingo.
Old 5/17/09, 6:58 AM
David P. Valley's Avatar
I don't check the pressure unless I see issues while running the entire bathroom, which is rare.
Old 5/18/09, 12:54 AM
Joe Funderburk, CMI's Avatar
David, the first 2 years I was in business, I never tested pressure either unless I suspected a problem. I now test every home and about 40% of them are either too high or too low in pressure. Most of those cases are excessive pressure.
Functional flow often seems OK even with 30 psi water pressure. You actually usually get very good functional flow with 120 psi water pressure! A pressure test on every home would be a wise thing to do in my opinion. If there is a plumbing failure due to excessive water pressure, guess who will get a call?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 5/18/09, 6:47 AM
Over 3,000 inspections performed with no pressure tests and I'm still waiting for that call.
Old 5/18/09, 12:05 PM
David A. Andersen's Avatar
Another "component assessment"?
Only functional flow "observations" required here.
There are other observations that indicate excessive pressure, at which time I test.
I would test pressure more but I can't seem to keep a calibrated gauge around. They freeze, get dropped, dropped on in the tool bag...
High pressure and compression fittings and plastic pipe don't go well together.
Pressure Regulating valves fail quite often. Who's to prove the pressure at the time of inspection?
A partial closed valve is only a problem when the "functional flow" test fails.
Mr. Pope, why don't you like to use hose bibs?
I like to keep the water leaks outside the house.
I am also gun shy around those blow down valves on the water heater. Most here are plastic, and don't do well over time when associated with heat.
BPI# 5015804
Old 5/18/09, 12:38 PM
Many times, the hose bibs are not regulated. The water heater is part of the "house" system and will reflect the same pressure that will be found at all interior fixtures and appliances.
Good judgement should always be used. If the heater is old, or if there are indications that there will be any problem, I will look for an alternate source.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 5/18/09, 1:57 PM
Seems like all the more reason to test the hose bibs. Wouldn't you want to know if that part of the system is excessively high? There are fittings there too that are subject to failure.
Theodore Roosevelt
Joe Funderburk, CMI
Old 5/18/09, 2:45 PM
Richard Mangold's Avatar
Richard Mangold Richard Mangold is offline
The NACHI standard states: "Inspect and report as in need of repair deficiencies in the water supply by viewing the functional flow in two fixtures operated simultaneously."
Isn't anything beyond visual (use of pressure guage) increasing your risk when you go beyond visual and reporting your observation?
Rich Mangold
RCM Home Inspections, LLC
www.RCMHomeInspections.com
Email: Rich@RCMHomeInspections.com
Phone: 847-698-5993
Old 5/18/09, 5:09 PM
Many times, hose bibs are not part of the house system. Separate piping is often installed for irrigation and other uses. Only the house/building supply requires regulation if the pressure exceeds 80 psi. There is no such requirement for piping outside of the building/house.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Water pressure too high? psiposs Plumbing Inspections 24 3/31/08 2:11 PM
New Washington Legislation Submitted gdomagala Legislation, Licensing & Legal Issues for Inspectors 293 2/10/08 2:20 AM
Water Heater Pressure Valve wrosario Plumbing Inspections 3 7/7/06 8:27 PM
