Go Back   InterNACHI Message Board > Specific Inspection Topics > Plumbing
Plumbing Contains discussions about plumbing.
Old 4/1/09, 12:18 AM
David Nasser David Nasser is offline
Default Water Pressure 75 psi .... question
Water pressure test 75 psi at the outside faucet where the house cutoff
is located...right by front entry door...Ran all faucets and baths on the inside
house and flushed toilets...did not notice anything abnormal.
Plumber did come out to the house to upgrade water heater. Installed a
TPR pipe, earthrquake straps and a pan. Water heater was located inside
house in a closet.
The buyers been in the house for a week. She saying water pressure is
low...and really gets effected if water is running in more than one place at
the same time.
Such as washing dishes and taking a shower.....
Anybody know what could be causing this .........
Find an InterNACHI certified Nebraska Home Inspector (and anywhere else in North America)
Old 4/1/09, 1:54 AM
Default Re: Water Pressure 75 psi .... question
Distribution pipe blockage? A section of galvanized supply pipe with the bore reduced by corrosion?
A leak?
That photo looks like screensaver I used to have.
EXPERT WITNESS
Director of Green Building
Director for International Development
(303) 717-8940
(303) 258-8289
Old 4/1/09, 2:35 AM
the same time.
Low flow
"Never ever threaten anyone in Camoflage"
Tim Wilson
Old 4/1/09, 10:18 AM
Jeffrey R. Pope's Avatar
Galvanized supply pipes. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/1/09, 11:58 AM
After looking at the picture again, this is probably the best answer so far.
Tim Wilson
Old 4/1/09, 12:07 PM
Joe Funderburk, CMI's Avatar
Did you check for functional flow during the inspection? In my states, we are required to. Generally, that means running the shower and flushing the toilet at the same time. If there is no reduction at the shower, then that is considered functional.
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 4/1/09, 7:24 PM
Wayne B. Wilson's Avatar
did they install a valve at the tank?
Old 4/1/09, 7:46 PM
Gary Oleski Gary Oleski is offline
"Anybody know what could be causing this ........."
Imagination? - had one like that in Connecticut last year. She would take showers at the gym that had a big, no restriction shower head. Just not the same at home.
Gary Oleski Home Inspections
Home Inspections Connecticut
Connecticut . 06610
NACHI04012833
CT#HOI.341
C M I
Old 4/1/09, 8:03 PM
Michael Larson's Avatar
Any whole house water filters or water softener?
"Never underestimate the difficulty of changing false beliefs by facts."
Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
or
Minnesota Home Inspector
Old 4/1/09, 11:02 PM
...a big, no restriction shower head...
Sounds like the "Commando 450" (Seinfeld episode).
Joe Funderburk, CMI
Old 4/2/09, 12:13 AM
Richard Fitzwater Richard Fitzwater is offline
Reduction in pipe size is likely the cause. Or too small of a main line to the home. Sellers' Disclosure?
If it worked fine prior, I agree with the interior corrosion of the galvanized pipe.
Richard Fitzwater
FYI Property Inspection
El Paso, TX
TREC#8317
www.fyiproperty.homestead.com
Old 4/2/09, 12:34 AM
Odd, I seemed to encounter a flow problem yesterday myself????
Tim Wilson
Old 4/2/09, 4:43 AM
Russel Ray's Avatar
Mineral buildup in the pipes from all the wonderful minerals in our water supply. At least down here in San Diego.
  • Need a positive networking site? Click here to join Active Rain, a networking community of over 140,000 real estate professionals helping others.
  • NACHI 2005 U.S. Member of the Year
Old 4/3/09, 10:43 PM
jkogel jkogel is offline
Brian, is that some Arizona prehistoric water that's spewing out of that shack??
Old 4/4/09, 12:49 AM
Looks like a PRV in the line. Has somebody screwed with it???
Site grading and drainage wdevries Canadian Inspectors 5 10/6/09 10:23 PM
Water Pressure..... David Smfh Plumbing 7 5/4/08 1:49 PM
Hot Water Heater djohnson6 Plumbing 12 12/28/06 9:18 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
