What's the highest (or lowest) pressure you've measured at a Home Inspection?
I've had lots near 140-150 or so... 170 psi measured yesterday in Palmdale is definitely one of the higher numbers I can remember. I've measured about 20 psi from wells as well. You didn't need a gauge to know there was something outta whack. |
| Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
My home 185 You did not need soap in the shower off comes a layer of skin .
I reduced it down to 45 lbs much nicer . Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Highest pressure ive come across so far is 90psi
Lowest I've has was 35psi on a well. Home owners knew of the problem the had a new pressure regulator ready to install laying next to the incoming line. Maximum water pressure should not exceed 80psi. Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas Active Rain Member |
My highest has been 120...
George Russell George Russell Professional Inspections Austin,Texas TREC # 10215 512-296-9538 http://georgerussellprofessionalinspections.com/ http://www.facebook.com/austinhomeinspections |
Gotta be sure your gauge isn't wacked also, I got high readings once, didn't catch it for a couple houses. oops
J.Szczesny 4 Seasons Home Inspections Washington State Inspector # 711 800 5th Ave #101-385 Seattle, Wa 98104 (206)391-0285 online @ www.4seasonsinspects.com email @ info@4seasonsinspects.com toll free cal @ 866-512-9972 "For the best protection, get the right inspection" |
My street pressure is 180 psi. Much of Santa Clarita has ultra-high pressure. Regulators don't generally last more than 4 or 5 years in our area.
| Reverse Osmosis | phinsperger | Plumbing Inspections | 3 | 10/30/07 6:28 PM |
