During an inspection today when I checked the pressure, my gauge read 120psi. WOW! I went to another bib, ran a little water, and rechecked it. It then read 60. Went back to the first bib, 60 also. There was a pressure tank on the supply side of the gas HWH. Why would the pressure be so high? could it be from a faulty regulator?
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
| Find an InterNACHI certified Colorado Home Inspector (and anywhere else in North America) |
rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
Sounds like it was working properly. Most houses (here at least) to not have any backflow prevention at the meter, so we don't get that happening. Many regulators do allow backflow, but not all. That is the purpose of having the tank. |
Thermo expansion?
That's what I was thinking too. Either that or a failing pressure reg. The gauge pic will make a great pic for my site.
One hose bib may be on the supply side of the incoming water line, and the other on the downside of the water pressure regulator, if there is one.
I thought of that but I could shut it off in the garage, so that would rule the before out.
Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
Sometimes the Seat/Stem module can be faulty or have some debris (typical of "creeping") at the Pressure Reducing Valve/ or Regulator.
Only mentioned as quickly running some water can temporarily resolve this, then the pressure will "creep" back up. Could be a couple minutes... could be hours. I've made a habit and leave my Pressure Gauge on the Bibb for quite some time. Even the $15 ones have a red sweep on them, indicating the highest pressure measured during the time you left on. This can indicate creeps or increase in water pressure that may be of concern. Water pressure probs can be a little tricky. Report issue and defer to plumbing or qualified contractor/technician and limit the amount of "fix" prescribed to or for the contractor. Negative results can happen from recommending "fixes" ie.... Recommend a repair to X Widget as it makes sense too. Y Widget was the real problem at 5 times the cost. Mr Inspector... I woulda called someone, but YOU were pretty sure that the X Widget was no good! We all want to help people solve their problems, just don't create one for yourself. Tim |
| Condensation Drain line question | acassady | Inspecting HVAC Systems | 25 | 2/26/12 11:40 AM |
| Site grading and drainage | wdevries | Canadian Inspectors | 5 | 10/6/09 10:23 PM |
| Loss of water pressure | dsearcy | Plumbing Inspections | 3 | 4/9/08 11:52 PM |
| Hot Water Heater | djohnson6 | Plumbing Inspections | 12 | 12/28/06 9:18 PM |
