Old 2/7/06, 8:40 PM
msaxton msaxton is offline
Default water pressure test
What is the easiest way to test the water pressure, could a guy make a simple tester wtih a pipe that screws onto a faucet with a pressure guage on it , what do others use
Old 2/7/06, 8:50 PM
Jeffrey R. Pope's Avatar
Default Re: water pressure test
How about a water pressure gauge?
Am I missing something here?
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 2/7/06, 9:55 PM
Iknow what a water pressure guage is,,, I'm asking the easiest way to do it make one to fit on the threaded part of a kitchen faucet, on a outdoor faucet (not all houses have them) (and not all water heaters have one) sorry if this seems stupid, but im not going to tap into a water line, whats not to follow?
Old 2/7/06, 9:58 PM
dbush's Avatar
dbush dbush is offline
Send a message via MSN to dbush Send a message via Yahoo to dbush
Please Note: dbush is a non-member guest and is in no way affiliated with InterNACHI or its members.
Exterior hose bibs and washer supply pipes make great placs to check the pressure.
Old 2/7/06, 10:02 PM
thanks,didnt have anyplace to check it, except for the unthought of washer supply line, otherwise no normal faucets, and not one on the water heater,I thought all water heaters had to have one but this is an old old electric heater and it doesn't. I will make a guage up to fit it
Old 2/7/06, 10:09 PM
Michael R. Boyett's Avatar
This one from Rainbird has the threaded hose bib adapter. I bought one at Lowe's recently for $10. You will, of course, need a hose bib to attach it to but you don't have to make anything up, just buy one. Am I missing something?
Old 2/7/06, 10:36 PM
tneumann's Avatar
tneumann tneumann is offline
I think he wanted to hook the gauge up to a kitchen faucet....in that case he would need a bit of "engineering" to get it to hook up...not to mention he would probably have to pull the aerator assembly off of the kitchen faucet...I wouldn't do that, my luck it would leak like a mother after that...
Just check the outside hosebibbs....if they don't have any, you probably cannot check it. If the outside hosebibbs are downstream of the prv (pressure regulating valve) then the pressure will likely be the same in the entire house.
If you cannot find an outside spigot (hosebibb)....and the washer is hooked up to a washer (difficult access) and the water heater doesn't have one....I think you are screwed....
Functional flow is your only option at that point, without "making" up a gauge for somewhere else in the house.....
Good luck.
Old 2/7/06, 11:12 PM
Go to any store that sells water beds or water bed supplies. They have adapters (fill kits) that fit your pressure gauge and most interior faucets - male and female.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 2/7/06, 11:15 PM
tneumann's Avatar
Thats right! I burned those brain cells up when I HAD a waterbed...must be why I forgot.
Old 2/7/06, 11:17 PM
Ted Allen Ted Allen is offline
Thats what I use. Works great
Old 2/7/06, 11:19 PM
Here are two different types.
The plastic one fits several sizes whereas the steel piece only fits one size.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 2/7/06, 11:23 PM
tneumann's Avatar
I love it here..I think I'll stay awhile....
Old 2/7/06, 11:25 PM
Wake up Tony, it's only a dream. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 2/8/06, 6:19 AM
Russel Ray's Avatar
From one who has had large aquariums with large fish, and even done some fishing in my aquariums, aquarium stores also have faucet adapters since the adapter and a hose make it very easy to siphon water out of the aquarium and, with the turn of a valve on the adapter, fill the aquarium up again.
Old 2/8/06, 7:39 AM
Adam J. Slimack Adam J. Slimack is offline
Beat me to it.
Reverse Osmosis phinsperger Plumbing Inspections 3 10/30/07 6:28 PM
Hydrostatic Pressure Test Edward D. Wend Plumbing Inspections 9 6/5/07 3:58 PM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
