Did a water pressure on line read 110 lbs, why would it be that high and what would your comments be?
| Need a home inspection in Mississippi? Check out InterNACHI's listing of Mississippi certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
We have a couple of neighborhoods here that has unusually high water pressure (in excess of 100 psi). Anything above 80 psi requires a pressure reducing valve be installed. Most water valves today on dishwashers, refrigerators, washing machines, toilet flush valves are made of plastic, however even copper can and will split under constant high pressure. A split supply in a slab (or inside a wall) is not a laughing matter. Have seen a few and it is a costly mess.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill Last edited by dedwards; 2/17/11 at 12:04 PM.. |
40-80 psi is operable range IMO, with 60 psi being ideal.
as mentioned, slab leaks suck, although they are likely caused by adverse soil/installation conditions along with pressure... but it's gotta be pretty high. Anyway, newer cross linked polyethylene systems don't tolerate high PSI well, nor do your fill valves in toilets and many other plumbing fixtures.. If the pressure in your plumbing is high... something in your plumbing is gonna die |
Neighbor and I both had pb piping....water came from higher up on the hill. I had a regulator on the water line....One day I am outside and there is a Plumber fooling around with the regulator on the neighbors line.. I asked did it fail, he said it never had one....10 years no troubles at all....lol
Water pressure was around 110 psig |
Keep in mind that sometimes a faucet splits off prior to the reducer. I still write that up.
I had one at 140 once.
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
Pressure reducing valves are one way and prevents pressure from water heating up to back up into supply line. Results may be worse than not having a pressure reducing valve if an expansion tank is not installed. Food for Thoughts, Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
| What might cause this many cracks? | bhamilton | Structural Inspections | 15 | 2/25/09 12:44 PM |
| New Washington Legislation Submitted | gdomagala | Legislation, Licensing & Legal Issues for Inspectors | 294 | 2/10/08 1:20 AM |
| Reverse Osmosis | phinsperger | Plumbing Inspections | 3 | 10/30/07 6:28 PM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 13 | 1/11/06 9:53 PM |
