Old 4/26/07, 9:42 PM
rnewman1 rnewman1 is offline
Send a message via Skype™ to rnewman1
Default Water softener drain or what?
Found this in the attic and wonder,
if this is how they installed a drain for the backwashing cycles on the water softener? Should it not idealy be below the top of the head od the softener and less than 20 feet away from the softener?
How would you wite it up?
Thanks,
Raymodn
Old 4/26/07, 9:47 PM
Michael Larson's Avatar
Default Re: Water softener drain or what?
Whatever it is
no trap
no air gap
Old 4/26/07, 9:48 PM
rmccullough rmccullough is offline
Drain for Water Conditioning System improperly connected to Waste Drain Vent in attic.
Short simple and to the point.
Old 4/26/07, 10:08 PM
Charley L. Bottger's Avatar
Are you sure it is a water softener drain and not a condensate pump discharge as the hose in your pic looks larger than most water softener drains that I see. I can not imagine running a water softener drain to the attic but I suppose any thing is possible in this business. Its not right regardless.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 13 1/11/06 9:53 PM
