Old 1/13/08, 11:04 AM
James M. Troth's Avatar
James M. Troth James M. Troth is offline
Default Water softners and cast iron pipes
Had a thought the other day. Since salt is corrosive, will the brine from a water softner lead to corrosion of a cast iron drain line? Also how about the sodium in the water, does it effect galvanized pipes or is the amount too low to cause issues?
Habitation Investigation LLC
http://www.homeinspectionsinohio.com
Old 1/13/08, 11:09 AM
Roy D. Cooke, Sr's Avatar
Default Re: Water softners and cast iron pipes
Yes it does, but I feel cast iron and galvanized pipes have all lived past their normal life, so I write them up as Recommending immediate replacement .
...Cookie
Old 1/14/08, 5:20 PM
Ian Gills Ian Gills is offline
Please Note: Ian Gills is a non-member guest and is in no way affiliated with InterNACHI or its members.
There's nothing immediately wrong with cast iron drain pipes. They are quieter and they are often good for 100 years, which means I'll get another fifty out of mine.
How misleading.
And Lord forbid you come across modern iron pipe. There is a huge difference in modern cast iron. Older cast iron was sand cast. This manufacturing method was a little less than perfect. The side wall thickness of the pipe could vary and it was possible for pin holes leaks and rust pimples to develop over time as a result of this deficiency. Modern cast iron piping is spun cast. This method creates a sidewall thickness that is very consistent and is virtually defect free.
Old 1/14/08, 5:25 PM
rwand1 rwand1 is offline
I see a lot of cast iron, saw some today. I have been told some insurers have not provided coverage due to it, but I think that might be an urban myth.
Anyway I don't think there is anything inherently wrong with it provided its sound and the joints packed and dry, no cracks. I think you would also find that the horizontal runs (undersides) would be most prone to corrosion particularly if not sloped properly.
Old 1/15/08, 7:46 AM
away away is offline
Raymond,
That may not be a myth. Last week, I received a call from an insurance agent looking for inspectors to "certify" that plumbing supply and drain lines were copper and pvc respectively in slab homes at 40+ years of age. It was some sort of slab coverage policy.
Andrew Way
Keystone Residential Inspection Services PLLC
www.keystoneinspections.com
Old 1/15/08, 8:31 AM
David P. Valley's Avatar
The only cast iron pipes I call out (needing replacement) are the exposed pipes that are pitting and seeping onto the floor.
Other that that, I've seen many cast iron waste lines that are 100 plus years old and could actually last another 100 years.
Old 1/15/08, 3:45 PM
mnahrgang's Avatar
Originally Posted by away
Raymond,
Andrew,
Just curious, How do you do that? You got a pair of x-ray glasses left over from the 60's?
Mark
Mark Nahrgang
www.HeyMark.info
Old 1/16/08, 6:11 PM
Mark,
Actually I told him that it was virtually impossible to make a determination like that without tearing into the walls, pulling up each and every commode, shower and tub. Oh and jackhammering the slab to pieces.
I politely passed doing the "certifications" by saying that I would not want someone coming back to me for "certifying" those two components were in use only to find out that a hidden portion of old galvanized drain or supply pipe leaked and caused a foundation issue. If the insurance company refused to pay the claim, I certainly didn't want to be the one left holding the bag. In my opinion there would simply be no defense that one could make. That is about where our conversation ended.
Andrew Way
Old 1/17/08, 7:48 AM
So... do most of you conclude that water softeners can cause a cast iron pipe to corrode faster?
Old 1/17/08, 10:44 AM
Michael Larson's Avatar
Probably not.
Any byproducts of the softening process(primarily Calcium and Magnesium salts)would be in contact with the cast iron for a short time because the normal waste water in the system would flush it away quickly.
Old 1/17/08, 1:11 PM
Michael
Seeing as most softners timers are set to regenerate in the early hours of the morning, and horizontal runs are not going to be flushed till the residents rise, what makes you so sure that the horizontal runs will not suffer? There are also salts being discharged along with the collect hard water deposits.
Old 1/17/08, 1:13 PM
Originally Posted by rwand1
Michael
Evidence please?
Old 1/17/08, 1:21 PM
Where's yours?
Old 1/17/08, 1:25 PM
Where's yours?
I stated "probably" and offered my reasoning. How about you?
Old 1/17/08, 1:32 PM
"Probably"
Nice try. I explained my theory and rationalize why.
