pmassie is a non-member guest and is in no way affiliated with InterNACHI or its members.
Have you ever seen a water tank safty valve connected to the hot water line
Like the drawing a just made... |
| Need a home inspection in Indiana? Check out InterNACHI's listing of Indiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Yes.
Was it a pressure-relief valve, or a combination temperature-pressure relief valve? If it's a TPRV, the sensor must extend into the top of the tank (generally) a minimum of 6 inches. If it's a PRV, it may have been used in conjunction with a Watts 210 gas shutoff valve. Do you have any additional information or actual pictures? IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 11/7/10 at 4:36 PM.. |
cant fid a pic but it's really a pressure-relief valve
OK..the valve is not independent, it is connecteted to the hot water line
There is no issue with having a PRV on the system. The question is - was over-heat and over-pressure protection present on the tank?
The diagram you have posted is insufficient to determine if the tank is properly protected. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
ok..
-valve installed = yes -is tank protected = yes if the pressure goes up will it activate the valve or go through the hot water line. to me a set up like that , where the pressure could go up the line doesnt make sense |
What type of protection was provided for over-temperature?
http://www.factsfacts.com/MyHomeRepa...sureRelief.htm
http://www.safteng.net/Accident%20Ph...0explosion.htm http://www.theplumber.com/explodingwaterheater.html Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
| Expansion Tank On A Hot Water Heater | rmarton | Plumbing Inspections | 6 | 2/28/10 3:41 PM |
| Hot Water Heater | djohnson6 | Plumbing Inspections | 12 | 12/28/06 9:18 PM |
