Old 2/13/07, 9:26 PM
David C. Mull, CMI's Avatar
David C. Mull, CMI David C. Mull, CMI is offline
Default Watt's 210
What can you all tell me about a Watt's 210?
Old 2/13/07, 9:33 PM
Jason1's Avatar
Jason1 Jason1 is offline
Please Note: Jason1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Watt's 210
Try here:
http://www.nachi.org/bbsystem/viewtopic.php?p=114309
Old 2/13/07, 11:09 PM
Jeffrey R. Pope's Avatar
The Watts valve is simply a gas-shutoff valve that is activated by high temperature water.
If there is a Watts valve on the heater, there must also be a pressure relief valve on the system. Also, many jurisdictions do not allow their use, except by "special permission."
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
electric heat question. cfuoco Inspecting HVAC Systems 13 10/4/07 4:50 AM
Voltage Drop dmacy Electrical Inspections 51 9/7/07 9:57 AM
Radiant Ceiling Heat hhull Interior Inspections 9 7/26/07 8:19 AM
Light Bulbs- All Ya Wanna Know pabernathy Electrical Inspections 9 4/18/07 7:22 PM
Do you think ICC should be req for HI's?? rbennett Legislation, Licensing & Legal Issues for Inspectors 130 2/15/07 3:04 PM
