In reference to inspecting a home with a well. When you are asked to do a flow rate, what methods do you use and how long do you allow the well to run to sustain the flow rate. What is the minimum you would call out. Thanks in advance.
Michael J. Parker The Neighborhood Home Inspector, LLC Home inspections in Clinton, Essex and Franklin Counties in NY State http://www.PlattsburghHomeInspector.com www.TheNeighborhoodHomeInspector.com |
| Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I do a pressure test. That's all.
I usually run the water for two hours @ 3 gallons per minute to start. It's important to check the flow every 15-20 minutes. I use the bucket method. There are gauges out there but I find a bucket is just fine. I would like to see at least 2 gallons a minute after two hours. I believe some lenders require a flow test.
David InterNACHI #08051301 NYS Lic. #16000038229 NYS DEC Cert # T4865884 518-505-8305 HouseAbout Home Inspections HouseAbout on Facebook NY Capital Region Chapter InterNACHI Last edited by dokeefe; 3/3/11 at 8:51 AM.. |
You can do a flow rate test by having a measured container like a 5 gal bucket. Then time running the water for 1 minute and see how many buckets it fills. There are a few problems with this basic test. Many wells have expansion tanks with a bladder. Many wells have storage tanks mounted high enough for different head pressures and some wells rely on pumps with no other means of delivery. All this can change the GPM.
Vaughn...do you have that meter? I see it is about $115.00. Looks like it may be worth it. Looks more proffessional than a bucket.
Just think how sporty one would look wearing that fanny pack though.
You would have to hook that up to an outside bib. Can't use it in the winter.
David InterNACHI #08051301 NYS Lic. #16000038229 NYS DEC Cert # T4865884 518-505-8305 HouseAbout Home Inspections HouseAbout on Facebook NY Capital Region Chapter InterNACHI |
In AZ you can use it year all year long. I'm going to purchase one...I'll let you know how it works.
I don't do enough wells here for the added cost of the equipment. Just another thing that can break down.
Thank you all for the info
Local guy around here is selling something like that. He put it on a tripod. Did a video on NACHI TV about it.
I refer to a well technician; those test can take as long if not longer than a professional home inspection if done properly.
Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
| Help with well flow test | Chris Inpittsburgh | Plumbing Inspections | 3 | 5/9/08 9:46 PM |
| efficiency of 15 yr old peerless | afrost | Inspecting HVAC Systems | 11 | 11/19/07 9:51 AM |
| Septic Systems | Rick Sovastion | General Inspection Discussion | 28 | 7/31/07 9:55 AM |
| Discounted hotel room rate for upcoming FREE 3-day Commercial Inspection course. | gromicko | Miscellaneous Discussion for Inspectors | 8 | 2/22/07 6:27 PM |
| Pressure and flow rate | rbennett | Plumbing Inspections | 4 | 10/2/06 8:56 AM |
