ok, city boy here, i don't do many well homes - my question is this: what does it mean when you operate hot water at a sink
(which didnt seem to get much use) and blackened water comes out.. 'is it sans oxidation "rusting" inside pipe - just built up and washing out? it did stop, as if it were a coating inside pipe is this a problem? Joseph Tribuzio 708 453 8447 Tribuzio Home Inspection Services CHICAGOLAND, ILLINOIS www.thishomeinspector.com ID# NACHI07062507 IL Lic#450.003128 Radon lic# RNIT2008216 Home Inspector Pro Software HIP Web Hosting |
| Need a home inspection in South Carolina? Check out InterNACHI's listing of South Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Is it galvanized plumbing?
Braun Inspection Consultants Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Copper as far as i can see... maybe some small flex connectors..rubber? a reaction from well chemicals
black rubber washers will oxidize for lack of a better term or fragment when seldom usage occurs
ever change a toilet tank that black crap from the tank/bowl washers sticks to and stains anything it comes in contact with i told you! you had to go see didn't you? ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
I have never seen that with copper plumbing before.
Best Answer - Chosen by Voters
Any time you shut off the water supply to your house, when you turn it back on you will get brown water sometimes even black. It is just sediment from the water system. Let the water run until it clears up and you will be fine. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
The tank is decaying .How old is the tank .
The sacrifical anode tube sounds like it has died . Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Iron and magnesium will cause the water to turn deep brown and than when exposed to air it wiill be almost black.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Thanks guys! making sense cause this home had 4 bathrooms, and 3 had 2 sinks each... uh ( and yeah i underbid this one)
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 6:45 PM |
| Article on Commercial and Residential Inspections and Assessment | mcyr | Commercial Inspections | 2 | 8/6/07 1:26 AM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 13 | 1/11/06 9:53 PM |
