I have a realtor that tells me the mortgage company may request a well inspection. Other than the normal visual stuff that I was able to see on it, what else would be involved. Besides water sampling.
They may require a flow test which you run the water at the highest point in the house for 30 minutes. Then fill a one gallon bucket in 20 seconds, this will verify that the flow rate is at least 3 gallons per minute.
Are you sure they aren't talking about a water analysis? I have a protocol for that if you need it.
I don't get into inspecting wells and you shouldn't either unless you have some expertise in that. I make it clear in my contract that my inspection of the water system begins after the pressure tank. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
dspencer is a non-member guest and is in no way affiliated with InterNACHI or its members.
I send a camera all the way to the bottom and inspect the liner and also report bottom conditions. Cost is $245.00 also a FHA water test $145.00
and flow test along with inspection of the expansion tank. |
Since some asked, here is the protocol I received from a laboratory I use. (I use a torch to sterilize because they are easier to cary in my truck--don't want to risk having a liquid spill in the vehicle.)
============================================= Water Sampling Protocol
Hi Joe,
Do you have a phone number for K&W Laboratories? I would like to get up with them if possible. thanks did a web search -- nothing. |
| Is this for real? | hgordon | IAC2 Indoor Air Forum | 47 | 10/30/06 9:31 PM |
| Arizona, one day mold cert | dbucknavich | General Inspection Discussion | 4 | 6/26/06 9:32 PM |
