Old 1/21/07, 10:01 AM
Peter C. Russell's Avatar
Default Wells
How many of you inspect private or community wells for pressure and flow.
I am moving this thread from the general discussion area to here.
Roy Cooke and I have been discussing this and I think it's a good topic as many of us live in rural area's.
Old 1/22/07, 7:20 PM
Default Re: Wells
Nobody has an opinion on wells!
That's a surprise.
Old 1/22/07, 7:22 PM
David P. Valley's Avatar
Default Re: Wells
I do well water testing and test for pressure and flow.
Do you have a question?
Joseph Hagarty,  CMI's Avatar
Default Re: Wells
Contact Joe Farsetta.
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 1/22/07, 7:53 PM
Default Re: Wells
I had posted in another section and Roy and I were talking about testing flow & pressure. I test for it because it can detect problems with the pump/main water line into the house and the water pump is just as important as any other component. So that said I was just wondering how many people do this inspection and how often do you write something up or how do you report it.
I always document the pressure, flow,and temp. at time of inspection.
Old 1/22/07, 7:57 PM
Default Re: Wells
Peter,
For Wells, our Office routinely samples Water for Analysis (of all types and levels of Testing) as well as Flow / Yield.
Well Head, Pump, Spring House, etc...are also inspected along with any conditions that may be noted.
Recommendations for followup are based upon the Laboratory results of the Water as well as the physical conditions of the Water Systems that are observed at the time of inspection.
Joseph P. Hagarty
Phone: 610-399-3675
Old 1/22/07, 8:20 PM
Default Re: Wells
Thanks Joe, I do the same but how do you inspect the pump, assuming it's submersible, other than flow/pressure
Old 1/22/07, 8:35 PM
Default Re: Wells
If the pump is submersible, it can not be physically inspected...
Flow, Pressure and Yield are all you have unless you have additional information with regard to Age, Depth of Water, Depth of Pump, etc... to make more informed recommendations with regard to repair/service/replacement of the pump equipment.
Joseph P. Hagarty
Phone: 610-399-3675
Old 1/22/07, 8:39 PM
Default Re: Wells
OK how about this scenario. The client is concerned about water pressure in the house, there is a water softening system installed and the client doesnt see the need for a water test. You test the flow and are lucky to get 3 gallons per minute, how would you write it up.
Old 1/22/07, 8:40 PM
Default Re: Wells
Thanks Joe, you annswered my question as I was writing my new post.
Old 1/22/07, 8:49 PM
Michael Larson's Avatar
Default Re: Wells
The water softener may also be restricting flow.
Old 1/22/07, 8:56 PM
Default Re: Wells
Yes your correct if not maintained properly. It can also be restricted by bacteria build up around the pump, the main line clogged or lack of pressure or sediment in the holding tank
Old 1/23/07, 7:40 AM
brepanshek brepanshek is offline
Please Note: brepanshek is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Wells
how are you testing flow and pressure properly?
Old 1/23/07, 8:01 PM
Default Re: Wells
I use a valve MFG by Watts Regulator, it's basically a gate valve with 2 gauges, one for gallons per minute and one for PSI. I test at a hose bib down line from the holding tank but as close to it as possible, How do you test?
Old 1/24/07, 5:03 AM
Default Re: Wells
Originally Posted by prussell
I use a valve MFG by Watts Regulator, it's basically a gate valve with 2 gauges, one for gallons per minute and one for PSI. I test at a hose bib down line from the holding tank but as close to it as possible.
I use the same gauge. Works very well.
As for the water testing, I use a local lab that is located 10 minutes from my office.
Today's daily door prize donated by Geoge Wells. gromicko Inspection Hardware, Software & Publications 8 7/25/07 6:59 PM
Covers for window wells rslocum Exterior Inspections 2 7/20/07 5:06 PM
Window wells rcooke Miscellaneous Discussion for Inspectors 10 7/14/07 8:47 AM
State of Illinois awards NACHI another H.I. continuing education license for wells. gromicko Inspection Education & Training 0 5/9/07 5:42 PM
Wells brepanshek Plumbing Inspections 9 6/28/06 9:15 PM
