Erol Kartal is a non-member guest and is in no way affiliated with InterNACHI or its members.
I'm buying a 30 year old home and of course the crawl space has problems. The sump pump is defective and a large area of the surrounding gravel is wet. The gravel is several inches thick over a barrier which is good, but what is the best way to dry this space out when the gravel is this thick? Fortunately no mold, but you can smell the yucky dampness in the home. The crawl space is not vented.
One idea I found on the web is to place a humidifier in the center of the crawl and have two fans point towards the dehumidifier. Another suggestion was to have a heat vent warm the crawl, but it's still summer. Suggestions appreciated. |
| Find an InterNACHI certified Montana Home Inspector (and anywhere else in North America) |
Dehumidifier would be my suggestion also, but may take a while to get the job done. How large an area is wet? Just around the sump, or the entire crawl? Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Jeffrey,
It's wettest near the crud pump and spreads out about 10-15 feet. The crawl is about 500 square feet. I'm wondering if poured concrete would be a good investment. |
You're pi$$in in the wind until you fix the lack of ventilation. Did you check the floor structure for moisture content and rot?
2 foundation vents, opposite sides of the crawl.
1 humidistat controlled van, something like this: http://www.ddchem.com/Crawlspace-fan.htm Works like a charm. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Dig a sump hole. Drain and pump it out.
Structure is fine. I don't get the ventilation thing. It's better that they're not vented.
It does have a sump pump but that needs to be replaced. I'm not sure there is enough moisture in the crawl space gravel to drain and discharge. So I'm looking for ways to dry it instead. I may start with a dehumidifier, but what do you think about adding a heat source to the crawl?
You've got wet soil and when it dries, the moisture goes into the air above it and it has nowhere to go after that except to get soaked up by the wood. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Replace the sump and see what happens.
After that some forced ventilation is in order to dry things up. You may need to treat the standing water in the gravel with a biocide before draining to kill off and possible mold or other organics. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Erol,
Tell us a little about the property. Any slope? bottom of a hill? just water table? I had a crawl space that could get white caps in the water when the wind blew through the vents. We put a linear french drain around two sides of the home and it has been dry since then, even during our 2 recent 100 year storms. Keep the water out, don't wait for it to get there and then act. Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Erol,
I sent you a P.M. with contact info. |
The slope is adequate but could be better. I think a new sump pump and a good dehumidifier will solve the problem. The gravel was wet but there were no signs of accumulated water. |
Joe's SC location is different than up here and would present more humidity problems. Quote:
I insulated the interior of the perimeter foundation but not the floor joists. That heat supplied to the crawl space rises and feels good on the tootsies. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
| Return air from crawl space | WHI | Inspecting HVAC Systems | 11 | 1/9/12 7:43 PM |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 6:31 AM |
| Crawl Space Venting issue | jfunderburk | Structural Inspections | 8 | 2/11/09 5:58 PM |
| Crawl space in under house | dnasser | Structural Inspections | 15 | 2/27/07 7:12 PM |
