Hi to all.
Do the flues need to have 12" minimum vertical rise before any transitions/bends occur? Is there also a horizontal minimum for this flue? Is there ever a circumstance that a single or twin WH configuration the TPRV can be omitted? Does this twin config meet those requirements? Do/would you mention the expansion tank resting against the flue and rafter? Thanks in advance. ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 6/2/09 at 12:55 AM.. |
1. Had to check with AHJ, but the vertical rise is within heater itself.
2. Don't understand horizontal minimum. (Little dense today) 3. NO. 4. N/A 5. Don't know of any regulation that says it can't. I wouldn't do it like that. Looks like the flue is going to melt some insulation over the years unless that is double wall. Is the area confined? Looks like they went to a lot of trouble to keep everything close. Don't want to work on that one. In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
[quote=jgilleland]1. Had to check with AHJ, but the vertical rise is within heater itself.
2. Don't understand horizontal minimum. (Little dense today) Why just today? Should there be a specific distance before the two flues join too avoid venting depletion or back drafting is essentially what I'm looking for 3. NO. 4. N/A 5. Don't know of any regulation that says it can't. I wouldn't do it like that. Me neither Looks like the flue is going to melt some insulation over the years unless that is double wall. Noted Is the area confined? YES attic Looks like they went to a lot of trouble to keep everything close. Don't want to work on that one.Not licensed no chance of that happening[/quote] Thanx for the reply! ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Barry what I can make of the NPC is 30" for WH. Seems to depend more on the size of flue than appliance. BTW they don't say center to center or outside to outside, so I figure you got 3" give or take.
| Cracked flue tile | bknowlton | Inspecting HVAC Systems | 6 | 2/1/07 11:37 PM |
| Flue Size when size matters? | msylvester | Inspecting HVAC Systems | 14 | 1/20/07 11:29 PM |
| TPRV line and condensate line marriage | ccarrington | Plumbing Inspections | 3 | 4/29/06 7:59 AM |
| Gas Log Flue venting height. | lagudo | Inspecting HVAC Systems | 34 | 4/7/06 1:42 AM |
