Old 2/21/09, 5:05 PM
Bill Smith's Avatar
Bill Smith Bill Smith is offline
Default WH vent pipe
I never saw this before - it looks like a dryer hose connected to the wh. All the references I have indicate a single walled metal pipe to be used as a gas appliance vent connector. Aside from that fact that it's not screwed into the collar, this one doesn't seem right. Any thoughts?
http://www.SmithHomeInspection.com
SmithHomeInspection@yahoo.com
NY State Lic. # 16000008304
631-434-5200
Old 2/21/09, 5:24 PM
wsiegel wsiegel is offline
Default Re: WH vent pipe
not even close
Old 2/21/09, 5:51 PM
Bill Smith's Avatar
Yeah, this one was not double-walled and the ends were cut eliminating any labeling that might signify an approved material. I thought so. Thanks for the replies.
631-434-5200
Old 2/21/09, 5:59 PM
Dale Duffy's Avatar
Hi Bill,
Looks like Dura Connect, single wall is fine until it goes through a ceiling. Was there double wall going through the attic?
I see these installations here regularly at newer homes, no problem.
Old 2/21/09, 6:03 PM
Jeffrey R. Pope's Avatar
Except for the missing connectors. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 2/21/09, 6:05 PM
Dale Duffy's Avatar
I think that was mentioned "Senior Zinsco"----
Old 2/21/09, 6:09 PM
My point being - the connector is absolutely necessary at the B-vent transition. If it doesn't have the proper connector, well, then it's improper
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 2/21/09, 6:18 PM
Dale Duffy's Avatar
I cannot see the ceiling in the picture, but your (invisible observations) would be correct if the proper connector(s) is-are missing---
By the way.....what's with NO Zinsco Pictures for the LONGest time?...I truly MISS THEM "Mr. Santa Zinsco Clarita"---Cookin Baby...Cookin---
You still in the "Inspection Business"?---
OK...I'd be happy to see at least one Federal Pacific doing a little cookin-----....work with me ole buddy---
Old 2/21/09, 6:27 PM
Joe Funderburk, CMI's Avatar
Hi Bill,
Agreed. (Don't overlook the insulation too close to the draft hood and vent pipe.)
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 2/21/09, 6:30 PM
Bill Smith's Avatar
Good call Dale - Dura Connect - a new one for me. Jeff, you got it right too - no connector at top or bottom. So: proper vent connector with improper connections at the wh and b vent. I love this bb!
Much appreciated guys.
631-434-5200
Old 2/21/09, 6:38 PM
Dale Duffy's Avatar
Hi Bill...I was just looking at my link...you know, I think that is rated as Type-B....but I am not positive...it says one inch clearance to combustibles as "B"...but I do not know the rating of the material without doing a little more digging.
Jeff Pope may know whether it's "B" rated or not even being single wall.
I know it DOES NOT bend all that easy (i've tried it)....really some tough material.
Oh...and I forgot about the "Twist Lock Connectors" which was cut from the portion you have posted at the draft hood.
From Dura Connect website:
B Gas Vent > 4" Dura-Vent B-Vent
SKU: 69222
Dura-Connect Gas Connector Pipe
Check out this revolutionary UL Listed gas appliance connector. It streamlines your installations and is a great timesaver (up to 80% labor savings).
This .012" thick, bendable aluminum connector has built-in, twist-lock fittings for fast, easy, professional installations. It's adjustable in length, providing up to 4" per foot in compression (zero stretch). It only requires a 1" clearance to both walls and ceilings. It is used as a connector between appliances and Dura-Vent Type B Gas Vent. Dura-Connect is available in 3" and 4" diameters in 24", 36", and 48" lengths. It comes with a 10-year warranty.
Old 2/21/09, 7:33 PM
Good call Dale - Dura Connect - a new one for me. Jeff, you got it right too...
What about me!
Theodore Roosevelt
Joe Funderburk, CMI
Old 2/22/09, 1:31 PM
Bill Smith's Avatar
Joe - you got it right too!!!
631-434-5200
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 36 10/27/10 11:21 AM
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 2:23 AM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 9:16 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 7:39 PM
