Old 2/24/09, 11:41 AM
wward wward is offline
Please Note: wward is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default what's this and what does it do?
inline shutoff valve with a small somthing on the outflow side with a small plastic tube running into the overflow pan for water heater.
This small tube has a steady stream pooring out.
What is is and what does it do?
<a href="http://s183.photobucket.com/albums/x...t=P1020326.jpg" target="_blank"><img src="http://i183.photobucket.com/albums/x...8/P1020326.jpg" border="0" alt="Photobucket"></a>
Old 2/24/09, 2:43 PM
Michael Larson's Avatar
Default Re: what's this and what does it do?
http://www.zurn.com/operations/wilki...ion/ISBVEC.pdf
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 2/24/09, 8:01 PM
Wayne B. Wilson's Avatar
Would it not be better to install a expansion tank?
Old 2/25/09, 6:20 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Only if you don't want to waste water.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 2/25/09, 6:32 PM
James H. Bushart's Avatar
Sounds, by the description of it being on the "outward flow" side, that it is improperly installed.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas.
Old 2/25/09, 6:41 PM
Sounds like it needs replacing...and Jim's right, it should be installed on the cold water inlet side, downsteam of the shut off.
Larry Kage, CMI
231 929 3525
