I know this was just on the board a little while ago but I can't find it. What is this? On the other side of the wall is a kitchen cabinet that is empty.
No basements here. Attached Thumbnails -- "Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
Maybe a vent pipe?
Those pics are very small, I think a little larger image will help in identifying
Try this
Vent for High efficiency furnace, discharge for sump???
no furnace , no sump
a shot of the inside might help??
without that... some type of vent... |
Thank you gjmagee!! GJmagee is correct! I don't know who GJ is, but I want to say THANK YOU!!! The following note reminded me that there was a cook top exhuast. It's a vent for the cook top!
This is the message: Hi Mark, Is the What's This question something you can answer? Just curious. My guess is a downdraft oven or cooktop exhaust. "Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
Mark, I don't think plastic, and it looks like plastic to me, is allowed for that use.
It's to small for a exhaust from range and should be corrected. If it is downdraft cooktop (i.e. Jennaire) they require a 6" exhaust. Same with draft hood above stove, they should be 6" to.
Older Jenn-aire's had 4" vents. Circa 1965 - 1992.
tg |
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 36 | 10/27/10 11:21 AM |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 9:16 AM |
| Identify ABS defective pipe | mcyr | Plumbing Inspections | 6 | 1/29/09 7:39 PM |
| Vent pipe | dlee2 | Plumbing Inspections | 4 | 9/18/07 12:28 AM |
