Is the fitting Poly? I never saw black water lines. They are under the sinks, hot and cold and looks like 1/2 inch. Are they poly?
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
Could be PEX, could be Polyethelyne Mark. No markings anywhere?
I did not see any markings on it.
I also have not seen black PEX.
What about the grey fitting?
Very Nice.... |
dharris is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hey guys.. I know what that is..
It's cheap plastic plumbing tha was used on mbl homes before and during polybutene.... and the valve is a home depot special plastic retrofit valve.. It's designed to replace the valve designed for the piping. I've seen that piping split, and piping come disconnected from the customer installed retro valves cause the home owner didn't installer the inside plastic or metal fitting properly, and cause more problems than polybutene.... back in those days the replacment piping was polybutelene with plastic fittings with alumiumn crimp rings. Heck.. it's a good material </IMG></IMG></IMG></IMG></IMG></IMG> |
Mike Parks is a non-member guest and is in no way affiliated with InterNACHI or its members.
Guys
It may be the same 'cheap' shtt that the water company uses! Watch what you say. |
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 36 | 10/27/10 11:21 AM |
| Identify ABS defective pipe | mcyr | Plumbing Inspections | 6 | 1/29/09 7:39 PM |
| Broken Pipe Removal | Gary W. Bowe | Plumbing Inspections | 10 | 11/1/07 3:31 PM |
| Flexible Fitting | inspector@carolina.rr.com | Plumbing Inspections | 4 | 6/9/06 9:05 AM |
