This was in-line where the propane line entered the home. It's where I often see a shut-off valve or regulator. Does this look familiar?
Not too sure, but it appears to be an electric valve.
Bruce Thompson Professional Inspector, Lic. #9199 Serving Tyler, Lindale, Bullard, Whitehouse, Mineola and the surrounding East Texas area. www.TylerHomeInspector.com NACHI 06081394 |
electricity and propane, hmmm...
Perhaps a "safety shut off" device.
Knowledge is power, but sharing knowledge brings peace! http://www.psinspection.com TREC License# 7593 Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC! Last edited by escanlan; 10/31/06 at 7:22 PM.. |
dthomas2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Very common - how about gas for your car, all kinds of electric around it. </IMG> |
It appears to have a connection for another gas line, but it was on a side of the home that wasn't used much, not near the deck, like it might be if it was some sort of "T" for a gas grill.
Where do the wires lead to?
tom |
I would say either a pop off valve for an over-pressure situation, or perhaps a seismic shut-off valve.
Brian R. Sumpter First Call Inspections Proudly serving most Bay Area Counties www.firstcallinspections.com |
I didn't follow the wires. Too many thing to investigate and they weren't paying for wire-following. I wound up recommending an electrical contractor for various things anyway.
Seismic is not really an issue around here. Regulators are designed to allow excessive pressure to bleed off. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
A google search for "propane shut off valve", "propane solenoid" seems to show examples of what you displayed. One results, shows a combination solenoid/switch and in which from inside the house you can isolate propane from entering the house. Now this has me guessing this is a 'fuel shut off', maybe energizes on demand, or designed to close on the flick of an emergency switch, or both.
hth, tom [guessing] |
Thanks Tom.
Any possibillity that it might be an electric safety selonoid valve?
Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I don't know what that is Marcel, but I kind of like the sound of it.
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 41 | 4/5/12 6:43 AM |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 8:16 AM |
| Identify ABS defective pipe | mcyr | Plumbing Inspections | 6 | 1/29/09 6:39 PM |
| Doing The Right Thing | gluck | Canadian Inspectors | 5 | 9/6/06 9:51 PM |
