Old 5/12/10, 9:23 PM
Joseph Tribuzio's Avatar
Joseph Tribuzio Joseph Tribuzio is offline
Default whats this on the water heater?
I cant figure what the thing is on the water heater with the black cap --can someone please help me out?
Joseph Tribuzio 708 453 8447
Tribuzio Home Inspection Services
CHICAGOLAND, ILLINOIS
www.thishomeinspector.com
ID# NACHI07062507
IL Lic#450.003128
Radon lic# RNIT2008216
Home Inspector Pro Software
HIP Web Hosting
Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/12/10, 10:05 PM
Bob Elliott's Avatar
Default Re: whats this on the water heater?
Attachment 36965
My only thought, is some kind of water hammer arrestor.
Old 5/12/10, 10:08 PM
yeah your right - that is what i seems like - but i hate to assume.
ID# NACHI07062507
IL Lic#450.003128
HIP Web Hosting
Old 5/12/10, 10:42 PM
Michael Larson's Avatar
N36
Water Service Vacuum Relief Valves
Size(s):
1/2, 3/4 in. (15, 20mm)
Description:
Series N36 Water Service Vacuum Relief Valves are used in water heater/tank applications to automatically allow air to enter into the piping system to prevent vacuum conditions that could siphon the water from the system and damage water heater/tank equipment. It consists of a brass body construction with NPT male inlet connection, and a protective cap. Series N36 has a low profile design, is tested and rated to ANSI Z21.22, and is CSA certified. It is suitable for low pressure steam and water service, and is ideal for use in domestic water heaters and supply tanks, table top heaters, jacketed steam kettles, unit heaters, low pressure steam systems, and steam coil heaters. Maximum Working Pressure: 200psi (14 bar), Maximum Steam Pressure: 15psi (103.4 kPa).
http://www.watts.com/pro/_productsFu...&pid=815&ref=2
Michael Larson
Hudson, WI
Old 5/12/10, 10:50 PM
Have you ever seen one hooked up to a HWH before?
It looks like a radiator knob,so it's funny that it can handle steam.
Old 5/12/10, 10:52 PM
No Bob but I knew it was a Watts from its shape.
It's part of their water heater safety protection line.
Michael Larson
Hudson, WI
Old 5/12/10, 10:58 PM
I just found an excerpt from the Illinois water heater code that states they are to be used when the fixtures are below the tank.
Joe was the HWH in the attic or top floor.?
Here is the excerpt........
f) Vacuum Relief Valve. Where a hot water storage tank or water heater is located at an elevation above the fixture outlets in the hot water system, or if the storage tank or water heater is bottom fed, a vacuum relief valve as listed in Appendix A, Table A (Approved Standards for Plumbing Appliances/Appurtenances/Devices) shall be installed on the storage tank or heater.
Link to the page.....
http://www.ilga.gov/commission/jcar/...00I12300R.html
Old 5/12/10, 11:04 PM
Off subject ,but an interesting tie in for Illinois Inspectors regarding the many posts on relief valves.
Any piping used for discharge from the relief valve shall be of metallic material and conform with the requirements of Appendix A, Table A (Approved Materials for Water Distribution Pipe) for potable water piping and shall drain continuously downward to the outlet.
Old 5/13/10, 12:00 AM
Yeah.....and dishwashers can't drain into the garbage disposal. But how many times do you not write that up...
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 5/13/10, 12:11 AM
Jeff
On my very last Inspection as a matter of fact Jeff.
I used to install all that stuff.
I am very a-nl on my reports.
The disposal has potential for cross contamination to the dishwasher.
In the city ,plastic water line is a no no.
Old 5/13/10, 12:20 AM
Dale Duffy's Avatar
I've never seem one like that here Bob.
Old 5/13/10, 12:21 AM
Dale Duffy's Avatar
Attachment 36965
Learn something everyday Joe...I have never seen one on a water heater configured like that.
Old 5/13/10, 12:23 AM
If you mean the vacum breaker ,I never noticed one while Inspecting.
How Larson comes up with these pictures ,I will never know.
Guessing he has a picture recognition software or he is Vulcan.
Old 5/13/10, 1:04 AM
Most of the time we will see the attachment to the disposal. If the hose is attached well above the bottom of the sink, I will rarely call it out.
Jeff
Jeff Wicklander
Old 5/13/10, 7:58 AM
You could ask Mike Meeker he should know
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
flammable vapor ignition resistant dbaucum General Inspection Discussion 35 2/19/08 1:42 PM
Solar water heating + electric water heater Todd M. Soper Plumbing Inspections 20 5/30/07 6:31 AM
Hot Water Heater djohnson6 Plumbing Inspections 12 12/28/06 9:18 PM
