Old 1/23/12, 8:26 PM
Joe Funderburk, CMI's Avatar
Talking Whats Wrong with this Water Service?
Water service pipe enters the foundation wall at the bottom right of the photo. See anything wrong?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Need a home inspection in Rhode Island? Check out InterNACHI's listing of Rhode Island certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/23/12, 10:40 PM
Default Re: Whats Wrong with this Water Service?
Where are all the CMIs?
Theodore Roosevelt
Joe Funderburk, CMI
Old 1/23/12, 10:41 PM
Michael Larson's Avatar
Joe, one Charley is more than enough
Michael Larson
Hudson, WI
Old 1/23/12, 10:42 PM
Chad Norlen, CPI's Avatar
Chad Norlen, CPI Chad Norlen, CPI is offline
From NACHI Plumbing Course:
With few exceptions, the water service pipe and the dwelling’s sewer pipe should be separated by 5 feet of undisturbed or compacted earth. The separation is intended to reduce the possibility of the sewer contaminating the potable water supply. Contamination can occur when there’s a leak in the building's sewer located near the water service pipe. The soil around it can become contaminated. If the water service pipe has a break in it, then contamination could occur. The water service pipe should not be located in, under or above cesspools, septic tanks, septic drainage fields or seepage pits.
Chad Norlen
SEI Inspections
Certified Professional Inspector
HVAC Journeyman - State of Idaho
EPA Certified Universal Technician
Old 1/23/12, 10:44 PM
That rule doesn't apply to plastic piping, which are 100% of the time laid in the same trench to the home. Nothing wrong there. The issue is in view. Not waste pipe related at all.
Theodore Roosevelt
Joe Funderburk, CMI
Old 1/23/12, 10:49 PM
Fudge.
PEX pipe requires horizontal support every 2.67 feet
Chad Norlen
SEI Inspections
Old 1/23/12, 10:50 PM
Hint: that black thing at the floor joist is the pressure reducing valve.
Theodore Roosevelt
Joe Funderburk, CMI
Old 1/23/12, 10:56 PM
Whatever that white pipe services (hose bib?) is seeing full pressure
Chad Norlen
SEI Inspections
Old 1/23/12, 11:00 PM
Ding! Ding! Ding! Ding!
Whether or not the pressure at the hose bib was < 80, it could be > 80 depending on the time of day you measure it. And it could be higher at any point in the future if the municipality increases system pressure.
Theodore Roosevelt
Joe Funderburk, CMI
Old 1/23/12, 11:32 PM
Stephen W. Stanczyk's Avatar
Did it go to a hose bib or a sprinkler system? A Tee prior to the pressure reducing valve is quite common for landscaping purposes and distant point of use faucets especially on larger parcels.
Stephen Stanczyk
Old 1/24/12, 7:49 AM
Jeffrey R. Jonas's Avatar
Not applicable! Didn't you see the Air Gap!!!
Old 1/24/12, 8:17 AM
Hose bib.
Theodore Roosevelt
Joe Funderburk, CMI
Old 1/24/12, 10:15 AM
Jeffrey R. Pope's Avatar
The location of the regulator is more of an issue than the fact that an exterior hose bib is not regulated.
The pressure should be regulated before it enters the structure, not somewhere within.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 1/24/12, 10:51 AM
Sean Fogarty's Avatar
Around here it is common practice to allow an exterior hose bib to be off the regulated system. I have argued this case in point before.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 1/24/12, 11:23 AM
It may be common practice, but it is a defect in my opinion. There are at least 2 fittings (at the T and at the hose bib) that could be overly stressed by high pressure and flood the crawl space.
Theodore Roosevelt
Joe Funderburk, CMI
Home Inspector Listings jbowman Miscellaneous Discussion for Inspectors 230 3/21/12 9:35 PM
What might cause this many cracks? bhamilton Structural Inspections 15 2/25/09 12:44 PM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
