Old 2/22/07, 4:08 PM
David C. Macy's Avatar
David C. Macy David C. Macy is online now
Default Whirlpool crudge
What is the best product to clean the jets of a whirlpool tub?
Old 2/22/07, 5:29 PM
Charley L. Bottger's Avatar
Default Re: Whirlpool crudge
Bleach, Limeaway makes to much foam it would be out on the floor.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 2/23/07, 2:01 PM
jkormos's Avatar
jkormos jkormos is offline
I would follow the manufactures recommendations, some of them ok the use of bleach, just make sure you follow the ratio suggested
https://www.sani-bath.com/
http://www.jacuzzibathtubs.com/installation.htm
Joe Kormos
A-1st Look Home Inspectors Inc.
630-201-0933
Your 1st Choice in Property Inspection Professionals
www.a-1stlookhomeinspectors.com
www.a-1stlook.com
Let us look before you buy...for peace of mind
“Thinking is the hardest work there is, that’s why so few engage in it. ” Henry Ford
Old 2/23/07, 8:06 PM
Emmanuel J. Scanlan Emmanuel J. Scanlan is offline
Safest way (I use it on mine) is to fill the tub just above the jets and return. Use one to two gallons of white vinegar and run it for 5 - 10 minutes. Drain it, clean the crud, fill it again with plain water and run it. Repeat this process until the water is clean. If this is dome on a regular basis it will keep the jets and tubing clean and not damage it.
Bleach can be used but to much and to often can cause problems with seals, etc.
Knowledge is power, but sharing knowledge brings peace!
http://www.psinspection.com
TREC License# 7593
Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC!
whirlpool tub motor Scott Schultz Electrical Inspections 2 5/31/07 8:42 PM
Whirlpool Electric Water Heater bhartley Plumbing Inspections 2 4/20/07 10:41 PM
Cleaning Whirlpool Baths or Bathroom Spas? kkenny General Inspection Discussion 29 3/14/07 1:36 AM
