Old 4/18/07, 12:12 AM
Default White corrosion at water heater shut-off?
I'm used to seeing the green stuff. Any ideas?
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 4/18/07, 12:15 AM
Dale Duffy's Avatar
Default Re: White corrosion at water heater shut-off?
Minor leaks Kenton....ooozzzzzing..................
Old 4/18/07, 12:17 AM
Dale Duffy's Avatar
If it was my house I would try tightening the packing nut by the handle....or just replace the thing......if that didn't work......
rmccullough rmccullough is offline
Corrosion,, calcium mineral deposits I believe. ,
Old 4/18/07, 12:18 AM
Charley L. Bottger's Avatar
We call it scabbing over as Dale said dripping water. I would suspect that the water is very hard
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 4/18/07, 12:22 AM
Well yeah, it's definitely a leak, sometimes corrosion seals them if they're minor. I guess when they leak that slowly the chemical process is different. Usually they're slimy green.
(303) 717-8940
Old 4/18/07, 12:26 AM
Dale Duffy's Avatar
I like to poke at them a little, to see if it really is a leak......
Then all hell breaks loose........
Hope all is well up there Kenton...!!!....and the SNOW is gone.......
Old 4/18/07, 12:33 AM
Yeah, kind like holding an armadillo up by his tail, then looking a little closer to see what's that thing puckering at the base of his tail? Oh... bad news!
(303) 717-8940
Old 4/18/07, 12:35 AM
Dale Duffy's Avatar
OMG..........................
Old 4/18/07, 12:36 AM
Still snow above 6500 ft., peaks are pretty well covered.
(303) 717-8940
Old 4/18/07, 12:37 AM
Yep, most of us'll take the burst pipe.
(303) 717-8940
Water heater corrosion - help please... bwooddell Plumbing Inspections 6 2/10/07 7:17 PM
Water heater vent & corrosion to tank. dmacy Plumbing Inspections 2 1/4/07 11:01 AM
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 9:36 AM
TPR & Combusiton Air thejnicki Plumbing Inspections 16 9/18/06 8:55 PM
