I inspected a home, new construction. Ranch style with 2 bedrooms up, 2 baths up, kitchen up. 2 bedrooms down, 1 bath down and a kitchen down on the finish lower level.
In the attic I was able to see (1) vent stack (2 1/2") through the roof. Construction is in a rural area, no codes, with septic system. Builder completed the Plumbing! My question is with all these fixtures, with the layout of the plumbing from one side of the home to the other, should there not be a waste stack and atleast 2 vents? Steven Wessler SpyGlass Inspection Services, LLC Serving The Lake of the Ozarks, Missouri INACHI: 09021806 www.spyglassinspect.com |
| Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Did you see any auto-vents?
Fixtures should all back vent to the main vent line and exit the roof as a 3" vent. Would all drain to a 4" waste line.
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Robert,
First thanks for responding. No there were under sink vents visible. Steven Wessler SpyGlass Inspection Services, LLC Serving The Lake of the Ozarks, Missouri INACHI: 09021806 www.spyglassinspect.com |
Marcel,
Thank you for the reply. No 3" line out of roof. Steven Wessler SpyGlass Inspection Services, LLC Serving The Lake of the Ozarks, Missouri INACHI: 09021806 www.spyglassinspect.com |
I noticed that almost a hundred viewed my request for information, but only (2) members responded. I'm not sure if its because most were unsure and did not want to speculate or if it depended on what area of the country and did not want to speculate. For the Missouri members, most particular, those in the areas were there are no codes, it was explained to me by a master plumber that a single vent is used in alot of cases to vent the entire home. The toilets are the primary concern and the remaining fixtures are just re-vented to the single vent. It was said that this method is not the most desirable and can cause problems, but is common in rural areas.
| Insulating Your House from CMHC | mkyriacou | Canadian Inspectors | 10 | 2/14/10 3:50 PM |
| Garage floor same level as house a safety concern? | thorn2 | General Inspection Discussion | 11 | 1/25/10 3:33 PM |
| Coming soon. Free, online, fireplace and chimney inspection course. | gromicko | General Inspection Discussion | 15 | 12/14/09 4:19 PM |
| Meth House? | tallen | General Inspection Discussion | 27 | 4/6/09 6:21 PM |
