Old 5/13/10, 10:12 AM
Joe Funderburk, CMI's Avatar
Default Why cast iron in a new home?
What would be the reason for this? New home. 99% of the waste pipes were PVC.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Need a home inspection in Alaska? Check out InterNACHI's listing of Alaska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/13/10, 10:24 AM
Doug Edwards's Avatar
Default Re: Why cast iron in a new home?
Only reason I can think of is it is less susceptible to damage.
- John Stuart Mill
James F. McKee's Avatar
I've heard of it being used for noise reduction in large vertical drops...
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 5/13/10, 10:25 AM
mnahrgang's Avatar
Plumber ran out of pvc, and happened to have the cast iron on his truck that fit?
Mark Nahrgang
www.HeyMark.info
Old 5/13/10, 10:38 AM
I wonder why they did not put a clean out up at the top near the transition. Looking at the system again as a whole it looks like it could be very susceptible to some clogging w/o a method to clean it out.
- John Stuart Mill
Old 5/13/10, 10:40 AM
Michael Larson's Avatar
I agree. It is much quieter.
Michael Larson
Hudson, WI
Old 5/13/10, 4:32 PM
That is exactly the purpose.....we been using them in all of our homes since 1992.
The problem you have to be aware of is to make sure the bottom is supported due to its weight.
Old 5/13/10, 4:41 PM
mnahrgang's Avatar
Always learning something new. One of the coolest things about this job, and this message board as well.
Mark Nahrgang
www.HeyMark.info
Old 5/13/10, 4:55 PM
Curtis M. Vilt's Avatar
Curtis M. Vilt Curtis M. Vilt is offline
When I was a carpenter in Chicago I asked the same question and was told it was due to the fact that PVC released toxic gas in a fire.
Old 5/13/10, 5:59 PM
I agree with Jim. We do it all the time on Commercial Jobs for vertical drops to reduce noise.
This looks like it was planned for possible future of finishing the basement.
Old 5/13/10, 6:03 PM
Banned
Cleanout is at required location. The upper pipes can be snaked from above easily.
Since it is only mechanically attached to the abs/pvc, the cast is able to be removed to install a cold water preheat/heat recovery device.
Old 5/13/10, 6:43 PM
Agreed, a dandy cleanout at the base is all that is normally installed, unless the horizontal run is excessive or takes a turn in the horizontal direction.
Brian, what is a cold water preheat/heat recovery device that would be hooked up to a waste line?
Old 5/13/10, 6:52 PM
Here you go Marcel
Drain-Water Heat Recovery
Michael Larson
Hudson, WI
Old 5/13/10, 7:02 PM
Thanks Mike, and I have never seen nor come across anything like it.
Seems like something that would be used on commercial or industrial buildings.
House hold with two to four people dosen't seem like a very equitable savings.
Old 5/13/10, 7:04 PM
I agree with you Marcel but people get talked into buying the craziest things sometimes.
Like magnets to "soften" your water.
Does anyone really think they work?
Michael Larson
Hudson, WI
Orange County Home Inspections whandley California Inspectors 12 5/18/11 6:35 AM
Hiring a Home Inspector mkyriacou Canadian Inspectors 7 4/24/09 4:26 PM
