I never seen a tap on the sump pump drain pipe before. What for do you need it?
Yuri Olhovsky CMI, CEA, PHPI, RASDT National Home Inspector NHICC #00372 Richmond Hill, ON Canada NACHI ID 04070207 |
Some people, who would otherwise pay for city water, like to irrigate vegetable gardens or water flowers with sump pump water
Roy Cooke If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
Example June is the driest month of the year when water could be needed in the garden . Well water is much colder then sump water would be . The well could have enough for the home but not the garden too. Others just like the idea of saving their well. I am still open for other thoughts . Roy Cooke If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
I don't see a hose bib. Could it be a shut off valve that was used as a connection by a weekend plumber.
If it has much water coming from sump it will over load the bed . The normal house hold usage of the system will not allow the Bacteria in the tank to do its thing and out into the field goes human waste . Easy fix new bed about $25,000:00 in my area. Thanks Yuri . Roy Cooke If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
Jason1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
As for the gate valve, I have no idea what he would do that for..... |
On closer inspection.....
It looks like he would close that gate valve which would re-direct the water to the brass outlet below the valve, where I assume he would have a hose that he would use to feed something - plants, etc....... |
Interesting thought........ |
bandag is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hmmm....water needed because they were "growing" something inside? That doesn't sound good.
| Is it safe to quickly test a dry sump pump? | rervanowitz | Plumbing Inspections | 16 | 2/11/09 5:38 PM |
| sump pump/ejector pump | hziegenbein | Plumbing Inspections | 3 | 4/28/07 11:28 PM |
| Sump Pump Recall | jbushart | Plumbing Inspections | 1 | 2/15/07 10:50 AM |
| Water powered sump pump | rcooke | Plumbing Inspections | 7 | 1/6/07 9:32 PM |
