Old 12/11/09, 7:33 PM
Sean Fogarty's Avatar
Default Why I test the water pressure
I heard the buyers comment on how great the water pressure was. I know why. I did find a couple of leaks and the t&p valve was brand new!
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Find an InterNACHI certified Maryland Home Inspector (and anywhere else in North America)
Old 12/11/09, 8:06 PM
James A. Levy's Avatar
James A. Levy James A. Levy is offline
Default Re: Why I test the water pressure
Brand new 20 years ago!
Old 12/11/09, 8:30 PM
Chuck Evans's Avatar
Do I see copper, brass, black iron, galvanized and PVC pipe and fittings all within about 18 inches of run on that service? Does that win some sort of award for most materials used in the least space?
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 12/11/09, 9:02 PM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
Nice rusty old galvanized fittings on those supply lines. BTW...that is a pressure regulator, not a temperature and pressure relief valve.
Old 12/11/09, 9:20 PM
Scott, I know thats the regulator. The reference for the valve was because of the pressure. The new one was leaking slightly. They replaced the old one more than likely becuase of this. I suggested that a licensed plumber fix all and inspect further.
865-256-5397
Old 12/11/09, 9:30 PM
Sorry...forgot to paste James comment into a quote. That part of my comment was directed at his response.
Water Pressure Problem dcossar Plumbing Inspections 19 11/21/09 8:47 PM
Air Pressure or Water Flow bboerner Plumbing Inspections 8 1/29/09 12:00 AM
New Washington Legislation Submitted gdomagala Legislation, Licensing & Legal Issues for Inspectors 294 2/10/08 1:20 AM
Hot Water Heater djohnson6 Plumbing Inspections 12 12/28/06 9:18 PM
