Can anyone tell me the best/easiest way to blow the water out of the water lines as part of a winterization procedure?
Thanks Mike Morgan Central Texas Home Inspections mike@centraltexashomeinspections.com www.centraltexashomeinspections.com |
Hire someone to do it.
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I blow the traps out with air from a pressurized portable cylinder. You can buy the cylinders from Graingers.
and here I was thinking dynamite....silly me.....
Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Prefer RV antifreeze myself. He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
There are often sections of plumbing piping that do not have sufficient slope to drain. On homes I winterize in northern Arizona, I add a drain at the lowest spot I can find. Vent the system as you drain it, blow everything out with air and then add the ant-freeze to the traps..
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
I'd like to de-winterize myself right about now in northern Illinois! |
When you "winterize" a house or multi-family do you also blow out water supply lines. I've run into several with frozen copper pipe and to me it would seem advantageous to start at the meter and blow the lines as dry as possible through the farthest open valve (faucet). I never do any winterizing or de-winterizing myself and would like to know. I am pretty sure no one around here does this.
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
Jack that is one good looking dog!
Carla |
Thanks, I'd tell him you said so, but his head is to big already.
| Buyers Best Home Inspections | ddinwoodie | Miscellaneous Discussion for Inspectors | 6 | 9/4/06 8:20 PM |
