Old 7/30/09, 8:30 PM
Joshua L. Frederick Joshua L. Frederick is offline
Default 1900's framing/construction
What type of framing/construction is this? I know it's not a very good picture, but it was mainly beams connected with dowels/pins.
Thanks in advance!
1900s-framing-construction-321-and-323-jefferson-avenue-defiance-137.jpg 323 Jefferson Avenue, Defiance 137.jpg
Find an InterNACHI certified Montana Home Inspector (and anywhere else in North America)
Old 7/30/09, 8:38 PM
Michael Larson's Avatar
Default Re: 1900's framing/construction
Thanks in advance!
Timber frame.
Similar to this:
Michael Larson
Hudson, WI
[/I]
Old 7/30/09, 9:34 PM
gbeaumont's Avatar
Hi Joshua,
it is refered to as "Post and Beam construction" I'd have loved to have inspected that job.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 7/30/09, 9:48 PM
Peter C. Russell's Avatar
Looks like my house. 9 room colonial, all post and beam construction. Built in 1840. The trees they used for rafters still have the bark on them. Sills, 10X10 hemlock are still original that sit on top of dry laid granite slabs
Old 7/31/09, 12:29 AM
Originally Posted by gbeaumont View Post
Hi Joshua,
Regards
Gerry
I got to disagree with you on this one, Gerry. I see wall studs with rafters supported by a purlin system, which looks OK. The walls are lathe and plaster. I'm betting from the apparrent age that the studs extend down through the floor joists and are suported by the shear strength of nails instead of the studs resting on something solid. Not that it matters... minus signs of failure, it's fine.
It appears that the diagonal purlin braces are connected to the strongback using historic mortise-type connections instead of lap joints.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 7/31/09, 12:30 AM
Paul Pendley Paul Pendley is offline
Would love to reclaim that lumber if that home were to be torn down.
Paul Pendley
Premier Property Inspections
866-458-8516
Old 7/31/09, 5:30 AM
dbolduc dbolduc is offline
Please Note: dbolduc is a non-member guest and is in no way affiliated with InterNACHI or its members.
Back a couple of months I had the pleasure of inspecting a farmstead started in 1790. Home, small, possibly original barn and large barn all timber frame. Proper grading maintained for a couple hundred years with high foundation walls of cut granite and common stone resulted in very good survivability. Renovation is underway. Unfortunately we are losing too many timber frames. Most are already gone in my area. These are my favorite structures for both inspections and restorations.
Old 8/1/09, 9:28 PM
jkogel jkogel is offline
Look at it again, Kenton. That stud wall with the lath is a partition wall up in the attic. This could have been put in long after the original build. We can't see the house walls, but to support that framing, it is likely post and beam.
DECK FRAMING/CONSTRUCTION COURSE March 27, 2008 ksitzes Exterior Inspections 1 3/4/08 5:49 PM
DECK FRAMING/CONSTRUCTION COURSE March 27, 2008 ksitzes Miscellaneous Discussion for Inspectors 1 3/4/08 5:48 PM
Illinois State Chapter of InterNACHI DECK FRAMING/CONSTRUCTION COURSE ksitzes General Inspection Discussion 6 3/4/08 5:48 PM
Illinois State Chapter of InterNACHI DECK FRAMING/CONSTRUCTION COURSE ksitzes Miscellaneous Discussion for Inspectors 6 3/4/08 5:47 PM
