Old 7/27/08, 7:00 PM
Mac A. Craig Mac A. Craig is offline
Please Note: Mac A. Craig is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default 1950's Slab Foundation?
I am looking at a house built in the early 1950's. According to realtor, it is a slab foundation. However, walking around the outside, there is no "gray line". No crawlspace vents present and it does appear to be a slab foundation from interior. What type of slab might this be? Brick veneer on exterior all the way down past soil. No gray line. Any help would be appreciatted. Thanks
MAC
Texas
Old 7/27/08, 7:16 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
Default Re: 1950's Slab Foundation?
If your depending on the realtor to tell you what type of foundation the house is on, you might need some additional training. Just my opinion. Or are you "buying" the house?
Old 7/27/08, 7:18 PM
Michael R. Boyett's Avatar
Although not the best building practice, many homes in the south of that era and even later have the brick veneer all the way to and even below grade which would obstruct the ability to see the slab. Isn't there some carpet you can carefully lift a corner of and look for concrete?
Old 7/27/08, 7:40 PM
Marc D. Shunk's Avatar
Banned
Stomp on the floor, and that'll tell you pretty quick what you're dealing with.
Old 7/27/08, 7:49 PM
I am looking at buying, not inspecting. It does look like a slab foundation from the interior. No concrete visible around exterior of structure. I questioned realtor about foundation, she said she thought it was slab. Normally can see slab along exterior wall. Just looking for your opinions on what type of slab this would be.
MAC
Old 7/27/08, 9:14 PM
That's right.
Larry Kage, CMI
231 929 3525
Old 7/27/08, 11:48 PM
Mac, Are you having the home inspected? I am guessing not. Might be a good idea.
Lack of foundation vents usually indicates a slab on grade, but every now and then I see a house that was built without vents, which is a very bad thing in this part of the world.
Regarding stomping on the floor... If the floor is built on sleepers, you may reach the wrong conclusion.
Old 7/28/08, 3:24 AM
James Budrow's Avatar
James Budrow James Budrow is offline
The comment below is the comment we use when we find a home in our area with siding reaching the ground. You could replace stucco with any other siding that may be installed on the home.
The stucco extends to the soil without the benefit of a weep-screed. Weep screed is a horizontal strip of metal that isolates the stuccoed house walls from the foundation and allows them to move independent of the foundation. This not only prevents cosmetic horizontal cracks that are commonly seen at the base of many stuccoed walls but also isolates the stucco from the soil and inhibits the wicking effect of moisture being drawn up into the stucco which in turn creates the flaking and peeling that is common on such surfaces. Also, the absence of weep screed can lead to moisture-related problems. Therefore, the base of the walls on the inside should be monitored for any signs of moisture damage or mold, which is not apparent at this time.
James Budrow
American Pride Home Inspection Service
5714 Folsom Blvd Suite 106
Sacramento CA 95819
1-877-IB4-UBuy(877-424-8289)
http://www.InspectSacto.com
http://www.APInspectionService.com
http://www.SacramentoInspection.com
President-Sacramento Valley Chapter (InterNACHI)
Old 7/28/08, 9:12 AM
Hmmm...interesting description of a weep screed, to say the least. Can't say I've ever seen a weep screed on a brick veneer wall.
Old 7/28/08, 8:05 PM
Emmanuel J. Scanlan Emmanuel J. Scanlan is offline
MAC
It is also possible the area was regraded to correct an issue and they graded above the brick ledge as that was the only way to obtain proper grade. Unfortunately that correction method would be wrong. About the only real way to know is dig a little and see if you find the slab.
Knowledge is power, but sharing knowledge brings peace!
http://www.psinspection.com
TREC License# 7593
Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC!
Old 7/28/08, 10:48 PM
Bruce A. King's Avatar
All slabs are not going to be visible no matter how far you dig.
If you dig enough, you will see the footer, not the slab.
One method used here with full brick homes is to have the brick resting on the footer. The footer is poured long before the slab. (non-monolithic and non-floating slab)
The slab is poured inside the "box" of CMU's which have an L-shaped open CMU at the top where the concrete flows inside it and down into all the CMU's. Sometimes they pour a good concrete mixture inside the lower CMU's called grout before the slab is poured if the foundation wall is higher, ie. sloping lot.
The brick will be several feet underground and the framing a foot or more above the grade. So the framing is on top of the slab edge which is actually reinforced with the L-shaped header CMU around the entire perimeter.
www.BAKingHomeInspections.com
704 301-3207
Old 7/28/08, 11:45 PM
Bruce,
Slab-on-grade foundations here, even back then, were generally monolithic pours. Footers here are not required to be deep (usually 12" - 24"). If you would like to read about Texas slab-on-grade foundations here is a good reference for you http://www.houston-slab-foundations.info/. Of course these really are not Texas specific building techniques.
I am sure there have been many cases of older homes constructed with much different techniques than today. However, I have not run into any homes here that were intentionally designed to have the brick veneer buried well below ground as you described. I am sure other Texas Inspectors may wish to provide other information. Possibly they have seen what you are describing.
TREC License# 7593
Old 7/29/08, 8:19 AM
MAC,
You can also try the Tax Assessor office records (not sure where you are). Some of the Tax Assessor's will put the foundation type in the records. These are online for many offices. I have not run into errors with what they report but there is always the possibility.
TREC License# 7593
Old 7/29/08, 8:28 AM
Barry Adair's Avatar
It's a left coast thing...
MAC,
Hire a qualified inspector prior to closing, I'm available!
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 7/29/08, 10:43 AM
Is it a wood frame structure or brick and block?
Abraham Lincoln
Moisture in slabs mcyr Structural Inspections 7 8/20/07 8:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 11:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 8:53 PM
Common Defects List by Age of House trausch Inspection Education & Training 10 6/12/06 5:52 AM
