New house under construction with a full basement.
All of the deck header bolts are bolted through the ends of these 2x4 engineered floor joists. The other end is designed the same so it does not appear that anything special was designed into these joists for the deck load. The bolts are too short and not staggered but I am wondering if anyone has seen this method before. I recommended either verifying on the plans or obtaining an engineers letter of approval as well as noting the other issues. The buyer has plans to replace/add on to the deck so the loading could increase in the near future. Not sure what size deck is planned by the builder. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Everything that I've ever seen called for a minimum of 1/2 through bolts. It appears that are larger than that. The floor joists probably have limits on piercing, just like I-joists do, but you don't know what those limits are. I suspect that the size of the pieced joists are OK, and I'd be shocked if this substantially weakens the joists, but you may want to recommend that they get it OK'd by the manufacturer.
Regarding the lack of staggering, I hardly ever see it staggered and I've never seen a ledger split. If it's not split, it's probably not reasonable to recommend that it be replaced. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
| Check The Deck | wdevries | Canadian Inspectors | 1 | 7/9/08 2:00 PM |
| Another deck Collapse | rcooke | Canadian Inspectors | 11 | 3/30/08 8:03 AM |
| Max load allowed on 2x2 ledger | bking | Structural Inspections | 4 | 12/23/07 2:05 PM |
| Deck Failures | rcooke | Miscellaneous Discussion for Inspectors | 29 | 10/25/07 5:47 PM |
