What year did it start being required that purlins be at least as large or larger than the rafters they support?
Also what yr was the peak ridge board required to be as larger than the rafters it supports? This home was built in 90. Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
| Need a home inspection in Tennessee? Check out InterNACHI's listing of Tennessee certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Question 2: The ridge board (when required) must be a minimum of 1" nominal or 3/4" dimensional however when rafters can be framed to each other with a gusset or approved tie its not required. R802.3 The problem with the rafters are that they heel of the rafter is not touching.........the bracing you are showing is acting more as a kee wall and not purlin bracing where the braces are more perpendicular to the rafters. Jeff Last edited by jhaynes; 5/17/10 at 4:57 PM.. |
As far as the ridge goes I thought as current code is now that always the ridge should line up w/ or past bottom of rafters. For instance 2x6 rafters woud need a 2x8 ridge. Also, your picture 2 shows no collar ties which i assume and know were required back then as they are now at every other rafter at ridge connect. Joe Keresztury JWK Inspections Home Inspections in San Antonio, Schertz, Cibolo, New Braunfels, Boerne and all surrounding South Texas areas www.jwkhomeinspections.com Last edited by jkeresztury; 5/17/10 at 10:37 PM.. |
Even with the pitch this roof has?
Yes, the collar ties prevent uplift. With the steep roof the rafters are already headed in that direction.
Joe Keresztury JWK Inspections Home Inspections in San Antonio, Schertz, Cibolo, New Braunfels, Boerne and all surrounding South Texas areas www.jwkhomeinspections.com |
Joe & Jeffrey,
Thanks for the explanations. I did not even think about the collar tie issue. Some of these homes have so many issues (attic alone) that you can't seem to keep track of them all. What's more amazing is that this is a well known custom home builder in the 750k and up range. Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
