Old 6/16/10, 10:40 PM
mnicholet's Avatar
mnicholet mnicholet is offline
Please Note: mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default 2x4 structural knee wall footings
These 2x4 knee walls, have PT plates and foam gaskets. They are supporting 2x10 floor joists. This home is new construction. It appears that these knee walls supporting joists are built on slab. I could not define the difference between the slab and footings under these wall. Typically, I can see the joint between the footing and slab. My concern is obviously if these knee walls are built on 5-6 inch slab they may be lacking footings. What do you think and what is your recommendation regarding writing this up? It obviously has been passed by authority having jurisdiction. Thanks!
ID:	37531   2x4-structural-knee-wall-footings-pict0219-small-.jpg.JPG
ID:	37532   2x4-structural-knee-wall-footings-pict0218-small-.jpg.JPG
ID:	37533   2x4-structural-knee-wall-footings-pict0226-small-.jpg.JPG
Need a home inspection in New Jersey? Check out InterNACHI's listing of New Jersey certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/17/10, 7:39 AM
Default Re: 2x4 structural knee wall footings
It may be a thickened slab.
Without any adverse conditions, what is there to write?...remember our inspections are visual.
Larry Kage, CMI
231 929 3525
Old 6/18/10, 6:23 AM
No different than an exterior wall footing that you can not see........ you simply do not comment on it since its hidden.............. otherwise you would be commenting / speculating on all sorts of hidden components / systems.
Knee wall add on supporting joists mnicholet Structural Inspections 5 4/28/10 3:33 PM
Moisture Management mcyr Exterior Inspections 15 9/8/08 12:11 PM
VIDEO--Bowed Basement Wall, Cracks etc john bubber Structural Inspections 75 7/21/08 5:25 PM
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 3:05 PM
