I am going to explain this the best I can. If you have a deck, lets say 15ft by 15ft whitch is screened in with a roof over it do you need 6x6 posts or are your regular 4x4 posts ok. I am not sure when the change would need to occurr or if it depends of the weight or other factors. If anyone has any info it would be appreciated.
It would depend on many factors. Number of posts, spacing between, height of deck, etc.
Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
Just curious... If this is your deck and it is built already, why ask now?
Seven,
This is not my deck although it is a very nice one and I would not mind if it was. Michael, Thanks for the info. |
http://buildingcodes.jocogov.org/doc...eck%20Book.pdf corrected link
Bungalows to Mansions Professional Inspection Services, LLC dba 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
afrost is a non-member guest and is in no way affiliated with InterNACHI or its members.
i don't think your joist is going to span 15' so you're going to have at least three bearing points. you may need diagonal bracing, too. what you are supporting is the dead load (weight of deck) + the live load per local code + the snow load per your local code just dodge the question like we are! |
| Where's NACHI on this Website? | lcapaul | General Inspection Discussion | 77 | 7/31/07 5:00 PM |
| Pillar to Post member Frank Ross puts out nice press release. | gromicko | Miscellaneous Discussion for Inspectors | 1 | 8/4/06 2:05 PM |
| photo wanted of moldy bathroom in prior post | psiposs | Interior Inspections | 8 | 6/11/06 9:20 AM |
